Fixing a bent LG strut
    March 2020
Posted by Faux fisherman on Saturday, January 23, 2021 8:35 AM
I am just about finished with my 1/72 Airfix P-51 and one of my LG struts is bent pretty bad. I am afarid I will break it trying to bend it back, any help is appreciated.
Thanks
    August 2005
Posted by EdGrune on Saturday, January 23, 2021 8:44 AM
Use a hair dryer to warm the part so that it softens a bit.  A hair dryer allows more control  Using an open flame is more drastic.
if more catastrophically bent go ahead and cut apart at the bend. Drill holes in each part and insert a wire for strength.
    March 2020
Posted by Faux fisherman on Saturday, January 23, 2021 8:46 AM
Thanks I will give it a try.
    March 2008
Posted by B-17 Guy on Saturday, January 23, 2021 12:05 PM
Hold it under hot running water and carefully bend it by hand.
    September 2005
Posted by richs26 on Sunday, January 24, 2021 1:48 AM
I would make up a jig with the other gear designed to straighten the bent gear.  Then plunge the bent gear into very hot water from a pan on the stove, and set it on the jig and let it cool.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
Posted by Don Stauffer on Sunday, January 24, 2021 7:01 AM
There is a device known as a stamping iron, used by scrapbookers to make printing stamps.  It is available at Micheals (where I got mine), and probably at other crafts/hobby stores.  It is a mini version of a heat gun, with a lower temperature and airflow, but certainly enough to soften plastic.  I find much less list of overheating the plastic.  They cost $25-30 bucks.  I find it nice for softening decals too.
    March 2020
Posted by Faux fisherman on Sunday, January 24, 2021 7:15 AM
All good ideas thanks everyone. I wound up using a lightbulb to heat it up and bend it back into shape.
This is my first plastic aircraft in 40 years but won't be the last, I have the P-40 and Spitfire waiting in line.
