1/48 Monogram F-86 Sabre Jet
    December 2020
Posted by DM1975 on Sunday, January 24, 2021 11:25 PM
Pulled this out of the pile for my next projec. I decided to build it mostly out of the box.
Well the problem I have with it being built out of the box is that there just isn't enough arm rest on the seat.
And since I decided to do that I figured that the jet can't go forward without a throttle so...
Still... minimal scratchin. I gotta work on my painting and finishing skills more than anything.
    December 2020
Posted by DM1975 on Sunday, January 24, 2021 11:32 PM
Next is paint. I have seen a few different photo references and decided to go with a light grey interrior rather than the silver that the kit recommends.
I also decided to hand paint the instrument panel
    December 2020
Posted by DM1975 on Sunday, January 24, 2021 11:39 PM
I used some pre made washes I got in a kit of paints to add some depth. I have since swabbed it down with a q tip to lighten the effec.
Then I dropped some future onto each gage on the instrument panel. I did this about four times letting it dry between drops.
And just a shot of my work bench at the moment.
Posted by keavdog on Monday, January 25, 2021 12:56 AM
Brilliant work there.  That pit looks great.  Those monogram IPs are really nice and paintable.
Thanks,
John
    January 2015
Posted by M. Brindos on Monday, January 25, 2021 4:06 AM
Looking sweet! Nice detail painting!
- Mike Brindos "Lost Boy"
    November 2003
Posted by tempestjohnny on Monday, January 25, 2021 6:45 AM
Yea that looks awesome
    January 2018
Posted by dswebb on Monday, January 25, 2021 4:58 PM
Looks great! Will love to see the rest.
In case you are looking for any NMF paints for the exterior, I just recently bought/experimented/used the AK Xtreme Metal paints on a project. Very impressed. Dries quickly, easy to apply, no primer needed, and took "full strength" (no de-tacking) Tamiya masking tape without any lifting of color or finish. Easier to apply than Alclad, and tougher.
Did a test and under the conditions I sprayed (temp, humidity) the tape didn't lift it after 12 minutes of dry time (though I didn't mask the real project for 24 hours like I normally do, just to be safe). Was dry to the touch sooner than that.
I was really impressed with them. The different shades look good next to each other.
Just in case it's useful to you.
 Doug
Slidell, LA
    December 2020
Posted by DM1975 on Monday, January 25, 2021 5:51 PM
dswebb
Thanks for the info. Ive been thinking on this subject and was not sure if it was going to use just what I had or do foil or alclad. I do believe I may follow your recommendation on this.
Posted by jeaton01 on Monday, January 25, 2021 10:40 PM
Nice cockpit work.
John
    December 2020
Posted by DM1975 on Tuesday, January 26, 2021 6:42 PM
So other than breaking off the pitot tube things have been going together well. I got the fuselage and wings all together rather straight by gluing everything together really slow, section at a time.
The instrument panel and top doesn't fit too well so I decided to glue it in after the fuselage half's were together with the cockpit in place. I also packed the nose completely full of miliput to help is sit right after it's finishe.
So I figure I'm just going to pain this one with what I have available, which is some Vallejo and some Army paints. I decided to use black Stynylrez primer. The photo doesn't reflect this but I am currently polishing the ever loving crap out of it all now before I apply the top coat.
    June 2017
Posted by Chemteacher on Tuesday, January 26, 2021 8:03 PM
Looks great. I remember building this kit as a kid. Good memories.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    January 2015
Posted by M. Brindos on Tuesday, January 26, 2021 9:06 PM
That is still one kit I've never built. I've always admired it and wanted to build it though.
Looks like it's not fighting you lol. Looks great so far.
    December 2020
Posted by DM1975 on Tuesday, January 26, 2021 9:21 PM
Thanks. It is a pretty good kit I think. The fit is relatively good but you can get the cockpit off angle a bit. Plus the top of the instrument panel is supposed to glue onto a ledge on the back of the panel but it is almost nonexistent.
Plus I'm not sure on how accurate the cockpit details are I only did minimal research but I can tell you there is not throttle. Other than that it has some decent detail.
    July 2004
Posted by stikpusher on Tuesday, January 26, 2021 10:11 PM
You're doing a great job on this classic kit. The moldings and detail still look nice and crisp on this one. Monogram was usually pretty good about their detail accuracy in the era when these molds were cut. They were the king of the hill at that time, and pushing the standards higher.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
Posted by Don Stauffer on Thursday, January 28, 2021 8:40 AM
Great job!
    December 2020
Posted by DM1975 on Saturday, January 30, 2021 3:14 PM
Well I guess it's coming along ok. I have some spots I have to go back and touch up and still have a few rough spots to polish out but it's ok.
I added a little extra detail to the canopy frame behind the seat. I drilled out the clear antenna bulb and mixed some brown and yellow up and painted it inside where I drilled. I also raised it up a little and added some wires. Nothing special or anything like that as I wasnt planning on doing much more than just buildi the kit as it is.
    October 2007
Posted by pablon77 on Saturday, January 30, 2021 3:21 PM
Awesome work in the interior, the instruments looks great!!! Regards, Pablo
Time is money... el tiempo es un maní
    December 2020
Posted by DM1975 on Saturday, January 30, 2021 3:38 PM
I am thinking about spraying it down with future after I finish polishing it. Then painting the yellow stripes on that, and then spraying it all down with future again. I feel it would add depth and make it look more like bare metal maybe? But I'm not sure.
    January 2018
Posted by dswebb on Saturday, January 30, 2021 7:13 PM
Looking good!
 Doug
Slidell, LA
    January 2014
Posted by Silver on Sunday, January 31, 2021 11:30 AM
Great work on such an old kit.
