Revellogram's 1/48 F-4J Phantom Completed!
    August 2016
Posted by Keyda81 on Thursday, February 25, 2021 7:23 PM
I intended to build the F/A-18 Super Hornet next.  I started the Revell kit, and spent two days trying to make the intakes look presentable.  Once it came to adding them to the lower portion of the fuselage I decided it wasn't worth the headache it was going to cause.  The fit was horrible.  I tossed it back in the box, and ordered the Hasegawa kit.  So while I wait for that to come in the mail I'll build the Phantom.
Revell's rebox of the old Monogram kit.
I picked this kit up used.  The cockpit was already put together, but not painted.  Easy enough to get it painted.
Within a couple hours I had the fuselage, and wing assembly glued together.  Not much to the old Monogram kit.
By the end of the day I already had a whole airplane, and all the armament glued together.
Obviously a few areas that will need the putty, sand, prime, repeat.  Mostly the intakes.  I'll have to rescribe whatever panel lines I lose.  But I shouldn't have to spend more than a couple days working on the areas and getting it ready for paint.
Posted by keavdog on Thursday, February 25, 2021 7:41 PM
Wow, that's a lot of progress
Thanks,
John
    August 2016
Posted by Keyda81 on Thursday, February 25, 2021 8:21 PM
keavdog
Easy when there isn't much to the cockpit, lol.  The seats were already glued in, I just had to paint stuff, and put it in the fuselage.
    August 2014
Posted by goldhammer on Thursday, February 25, 2021 8:38 PM
Fast as you're going, M/D could have used you on the line back then.  Looking like you'll be done way before the new bug hits the porch.
    July 2004
Posted by stikpusher on Thursday, February 25, 2021 10:26 PM
VF-84? Very nice! I can't wait to see you do this one!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    May 2006
Posted by Shipwreck on Friday, February 26, 2021 6:32 AM
Keda81, you are at it again; building another one of the kits that I probably not get around to building, the Revell F-4. I am impressed with the detail of your instrument side panels. Are you dry brushing them or picking them out with a tooth pick?
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
    August 2016
Posted by Keyda81 on Friday, February 26, 2021 9:21 AM
goldhammer, likely as they haven't shipped it yet, lol.  It will sit all day as I'll be at the museum working on a much bigger subject.
stik, yep, VF-84.  Something about that paint scheme, and I thought it would be nice to have them all hung next to eachother.
Shipwreck, I dry brushed them with chrome sliver.  They were just too small and not quite raised enough for me to pick them out with a small brush or toothpick.
    April 2015
Posted by Mopar Madness on Friday, February 26, 2021 10:55 AM
I sure do have a soft spot for these vintage classics!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    August 2016
Posted by Keyda81 on Friday, February 26, 2021 12:15 PM
Mopar Madness
I had built this one once before, so I knew what I was getting into with it.  Sometimes they need a little work, but they make for fairly fast, easy builds, that can look great once done.  I love Monogram's C-47 kit.  I've built two so far, and have two more of those in the stash.
    April 2015
Posted by Mopar Madness on Friday, February 26, 2021 2:11 PM
I have been seriously thinking about adding the C-47 to the stash.  I just can't figure out how to get around sanding the raised river details along the fuselage seams. The kits (and box art) look great though.
Chad
On deck: Who knows!
    August 2016
Posted by Keyda81 on Sunday, February 28, 2021 9:52 AM
Mopar Madness
I've done 2 of those kits, and I just sanded all the detail off to the next line.  So it just never looked like it was even there.  There really isn't much you can do about raised detail.  I have scribed the missing section between two raised lines, and you really can't tell a difference.  I'm not for re-scribing the entire thing, I mess up way too much for that.  I'll scribe what I sanded off, and leave the rest raised.  Most other people that see my models wouldn't know the difference anyway.  I've never had anyone say anything and I share my builds on a few different facebook pages.
    January 2015
Posted by TheMongoose on Sunday, February 28, 2021 11:15 AM
Keyda81
Mopar Madness
the old RevellOgrams were great kits. Surprising how often they got the overall shape right whereas some modern manufacturers goof that up. I started avoiding these for just those reasons, losing the raised detail. Funny, now that I'm not 10 Iwant to get rid of that fuselage seam lol.
Have you seen Archer Fine Transfer before? They have rivets AND raised panel line detail in resin. 1/48 and 1/32 scale. Easy stuff to use and you can make the decal film they come on disappear under paint easily. Totally revives the classic kits in my mind.
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    April 2020
Posted by Eaglecash867 on Sunday, February 28, 2021 11:23 AM
Mopar Madness
If you ever need to replace parts of raised panel lines or rivets, have a look at the stuff Archer Transfers makes.  They have all kinds of different sheets of resin rivets and panel lines that apply just like water-slide decals.  The carrier film is nice and thin so the edges of that disappear when primer and paint go on at the end, leaving a nice set of new rivets or repaired panel lines.  I've used them quite a bit and they are extremely easy to use.  Using Milliput on the seams in those areas helps a lot too.  You can smooth that flush with a damp q-tip before it hardens so you won't have to sand.  When it hardens, its not fragile like another water-soluble putty is.
edit:  DOH!  Mongoose beat me to it with the Archer suggestion.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    August 2016
Posted by Keyda81 on Sunday, February 28, 2021 7:26 PM
I'll have to look into that.  Honestly from even a foot away though I can't tell teh difference between the raised portion, and the scribed one.
Some progress today.  Aside from a few little spots, and scribing in some lost detail I am done with the putty, sand, prime, repeat phase.
All the armament ready for paint.  Aside from the sidewinders.  I'm going to steal those from the spares bin.  I'm tired of filling injector pin holes, and the sidewinders in the kit have like 3 each.  No thanks, lol.
With any luck I'll have it ready for paint before the Hornet kit I ordered even ships.Indifferent
    October 2016
Posted by DasBeav on Sunday, February 28, 2021 8:05 PM
So far, so great, Keyda!
 Sooner Born...Buckeye Bred.
    May 2004
Posted by cbaltrin on Sunday, February 28, 2021 8:37 PM
Looks good. I've been working on the 72nd scale monogram F4J off and on for months. I think the 72 scale version is actually nicer--perhaps it's the age of the molds...
On the Bench: Too Much
fox
    January 2007
Posted by fox on Monday, March 1, 2021 6:42 PM
Looking great so far! Got one in the stash so I'll be keeping tabs on your build.
Jim Captain
Stay Safe.
 Main WIP:
    August 2016
Posted by Keyda81 on Tuesday, March 2, 2021 7:33 PM
Well things were going well.....until this afternoon.
I got the underside painted white yesterday, and left it to dry over night.
In the booth last night.
Was pleased with the job I did of molting the color a little bit, so it wasn't ultra bright white.
Went on to paint the upper half this afternoon, and ran into some trouble.  I questioned whether or not I should thin the paint a little more since it seemed a little on the thicker side.  Tested what I had mixed, and it seemed fine.  So away I go painting.  Don't realize until after I'm done some of the paint dried before it hit the model, and gave it that gritty, dusty appearance.  Grrr.  Ok, I've dealt with this before.  I rub it down with tack cloth to remove the grit.  Thinned the paint some more, since I'm assuming that was the cause, and tried again.  It did it again. What the heck?!  I took a break at this point and left it sit for a while.  When I came back to it there were some areas of the paint that had that cracked look to them.  Angry  So I had the bright idea to just strip the paint with enamel thinner.  Which worked, but it took me over an hour, and made a huge mess of things.  To top it off it seems with all the rubbing and cleaning I was doing it rubbed off a lot of the raised panel lines.
So here is my mess.
I've opted to go a head and rescribe the lost detail to the best of my ability.  This may take me a few days, but I know I can fix this mess of a Phantom.
One wing rescribed.
Compared to the other wing that I haven't done yet.
A bit of a set back, but these things happen.
Posted by keavdog on Tuesday, March 2, 2021 7:44 PM
What a bummer!!!!  I had that happen to me twice - both times I was painting over Tamiya white primer - maybe too much primer, not sure, didn't dry enough?  Last time resulted in a temper tantrum :)  I have no respect for 1/72  lol
Thanks,
John
    August 2016
Posted by Keyda81 on Tuesday, March 2, 2021 8:19 PM
keavdog, I have had it happen a few times, but never could figure out exactly why.  I always use the same primer, and the same enamel paints, thinned to the same ratio, sprayed out of the same airbrush at the same air pressure.  So I just don't get it.  I'm going to try turning the air pressure down a bit next time, and likely spray a guninea pig of sorts before I spray the Phantom again.
    November 2008
Posted by plasticjunkie on Tuesday, March 2, 2021 9:55 PM
How far are you keeping the airbrush from the surface you are painting? The only times that has hapenned to me is when I’m spraying far and the paint dries as it hits the surface. I thin my enamel paint to thinner about 40/60 and get smooth coverage using light coats at about 10-12 psi but every ab sprays different so experimentation with the spray distance and thinner ratios will help determine the best recipe.
 GIFMaker.org_jy_Ayj_O
    April 2020
Posted by Eaglecash867 on Wednesday, March 3, 2021 6:31 AM
I have had the gritty paint thing happen a few times when I was shooting paint at too much of an angle.  Now I try staying as close to horizontal as possible and I haven't had the issue for a long time.
    August 2016
Posted by Keyda81 on Wednesday, March 3, 2021 10:47 AM
plasticjunkie
Only a couple inches.  Which is why I don't get why I'm having problems now.  I'm pretty consistant with how I use my airbrush.  I think the paint 2:1.  2 parts thinner, one part paint.  Have always done it that way and usually don't have any issues.  I'm wondering if maybe the paint was no good.  I tossed it, and will use a new unopened jar, along with dropping the pressure down on the air compressor.  I wonder if it creeped up on me, and I just didn't notice.
    August 2016
Posted by Keyda81 on Wednesday, March 3, 2021 10:48 AM
Eaglecash867
That could be too, I'll give that a try on the next attempt.
    August 2016
Posted by Keyda81 on Wednesday, March 3, 2021 3:28 PM
Back at the rescribing this afternoon.  I can only take so much of this at a time, lol.  Literally maybe a couple hours, then I have to put it down.
While sitting there working on it, I'm of course thinking to myself is this even worth it?  Maybe I should just toss this kit in the box, and buy a new one.  It's going to look like crap anyway.  So after going back and forth in my head, and struggling to not mess up while rescribing I opted since I had the one top half completely done to throw some primer on it, to at least see how it looked before I made any rash decisions.
The left side is done.  Now mind you I'm going by what is left of the raised panel lines, which isn't much at all.
Left wing.
Left upper fuse.  Primer was still a bit wet when I took the pic.
All in all I don't think it's looking too bad.  It looks pretty rough before getting primer on it though.  I suppose I'll keep plugging along instead of pitching it, and taking the easy way out.  To those of you that purposely rescribe all panel lines, you are nuts, lol.
    May 2006
Posted by Shipwreck on Wednesday, March 3, 2021 5:33 PM
Keyda81
That-a-girl Keyda, I know you can doi t!
On the Bench:
    January 2020
Posted by wpwar11 on Wednesday, March 3, 2021 6:13 PM
I would say that's a damn fine recovery.  Press on
    April 2020
Posted by Eaglecash867 on Wednesday, March 3, 2021 8:13 PM
Good save, Keyda!  I'm with you on rescribing the whole plane after removing all of the raised detail.  Those guys are nuts!
    August 2014
Posted by goldhammer on Wednesday, March 3, 2021 8:47 PM
From an old Phantom phixer,  the AF threw away enough of them.   Nice save in not giving up on the old girl.  You ladies have to stick together.
    August 2013
Posted by Straycat1911 on Thursday, March 4, 2021 1:14 PM
It's a Navy Phantom Vietnam era; I wouldn't fret too much over the appearance.
The real things probably looked beat up after a few weeks on the line as well.
