Panel lines
    February 2021
Panel lines
Posted by SchemeAddict1981 on Thursday, March 4, 2021 5:51 PM
I'm new to modeling and I'm going to attempt panel lining with a pencil. I've already applied Testors spray laquer to the Testors light aircraft grey base I used and plan on using Dullcote after I apply my decals. Should i panel line and then apply Dullcote or do it after?
Posted by gregbale on Thursday, March 4, 2021 6:01 PM
Regular pencil tends to have a bit of a shine...so ideally the Dullcote should come after.
This also limits the likelihood of mucking up your flat coat through the inevitable handling that happens while drawing on the panel lines.
Greg
George Lewis:
    April 2016
Posted by RacerToo on Thursday, March 4, 2021 7:10 PM
  It might be helpful if you post a photo of the real aircraft you're building and pick our brains on how we would accent the panel lines. Just a suggestion.
    April 2020
Posted by Eaglecash867 on Thursday, March 4, 2021 7:35 PM
Raised or engraved panel lines?
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    January 2015
Posted by M. Brindos on Thursday, March 4, 2021 8:11 PM
The only thing to really worry about is making sure you clear coat the pencil lines or you can accidentally smudge them.
I will suggest doing one section at a time between clear coats. Basically save your work before moving on from the fuselage to the wing and such.
- Mike Brindos "Lost Boy"
Posted by Don Stauffer on Friday, March 5, 2021 8:11 AM
Depends on color.  Panel lines are not that noticable on dark paint.
Even on light colored paint it is easy to overdo these lines.  Less is more is the old mantra.
