Eduard 1/48 Oeffag Albatros
    March 2021
Posted by Rob Hart on Tuesday, March 9, 2021 8:26 PM
Mike Grant decals and Quickboost seat and exhaust. I also replaced the styrene machine gun blast tubes with Albion Alloys micro tubing.
Posted by Tojo72 on Wednesday, March 10, 2021 10:30 AM
Another nice job,those decals went down nice
cnq
    March 2013
Posted by cnq on Wednesday, March 10, 2021 10:36 AM
very very nice work. I love it.
Posted by gregbale on Wednesday, March 10, 2021 10:41 AM
Always a thrill to see those Kościuszko Squadron machines! Really neat history that many are completely unaware of.
Yours turned out beautifully!
Greg
George Lewis:
    March 2021
Posted by Rob Hart on Wednesday, March 10, 2021 11:44 AM
Tojo72
Actually, the only decals used were the squadron insignia. All the other markings were masked and painted. I have lousy luck with decals and avoid using them as much as possible.
Posted by Tojo72 on Wednesday, March 10, 2021 12:29 PM
Rob Hart
Tojo72
No wonder the makings look great,good job
    June 2013
Posted by bvallot on Friday, March 12, 2021 8:13 AM
Same here Rob. I love that engine and really love that prop. Well done. What are you using for your rigging and how have you gone about setting it up?
Also, a huge fan of your grass scene. Two thumbs!
On the bench:
Tamiya F4U-1  Kenneth Walsh
    March 2021
Posted by Rob Hart on Friday, March 12, 2021 10:12 AM
Thanks. I used .004 stiff stainless steel wire for the rigging. I bought it from the Small Shop years ago. It came in six foot tubes and is no longer available. However I recently found a new source; Ngineering out of Battle Ground, WA sells the same stuff in 10 packs of 12" lengths. The turnbuckles are 3 mm lengths of .4 mm brass tubing. You can cut your own tubing, but I buy mine pre-cut from Bob's Buckles. I anchor the ends of the rigging by running them through photo-etched eyelets (also from Bob's Buckles) that were glued into pre-drilled holes on the wings/fuselage/stabilizer, etc. surface. The grass scene is from a Model Scenics turf mat cut to match the size and shape of a plywood disc base. I did the laminated wood effect on the prop with colored pencils (see Youtube for some excellent tutorials).
