1/72 Hasegawa P-2H Neptune (P2V-7)
    April 2015
Posted by Wolfman_63 on Friday, April 16, 2021 11:24 AM
For my next build I will be doing another commission build. This will be a 1/72 Hasegawa P-2H Neptune (P2V-7) of VP-4. The P-2 was a Lockheed built Maritime Patrol and Anti-Submarine Warfare aircraft. This aircraft flew from 1947 until the late 1960’s for the US Navy and continued to fly until 1984 for other countries. The client is having this built to match his Father’s aircraft. I will be making all the specific decals and weathering it to match actual photos. I will also bescratch building additional details as needed.
This kit is the Minicraft/Hasegawa version. This kit was released back in 1972. Many kits back then did not have the better details as more recent model kits. The cockpit consists of only 6 parts and no details on the parts at all. After reviewing some references online I modified the seat, made my own instrument panel, ( see https://davidsscalemodels.com/tips-and-tricks/making-a-cockpit-dash-from-scratch/ ) center console, detailed the rear bulkheads of the cockpit and nose area, and scratch built the control sticks for the pilot and co-pilot. The seats were painted with the international orange pads and I used small strips of Tamiya tape for the seat belts. The nose gear bay also lacked details so with some photo etch extras I added more details. Once the cockpit and nose section were completed I assembled the fuselage. The seams between the fuselage halves were difficult to get them to line up. I slowly glued the halves together then used Tamiya putty to fill the gaps and improper fit. As soon as the putty finishes curing I will be detail sanding for a while.
See more photos and details of this build from in my build log at https://davidsscalemodels.com/build-log/hp-2h-neptune-p2v-7/
Website:
David's Scale Models - https://www.davidsscalemodels.com
    November 2003
Posted by tempestjohnny on Friday, April 16, 2021 12:14 PM
Looks good I've got 2 of these in the stash
Posted by keavdog on Friday, April 16, 2021 12:23 PM
Nice start.  I really like the lines of this airplane but I've read that this kit is a bit of a bear.  I'll be following along.
Thanks,
John
    July 2016
Posted by WillysMB on Friday, April 16, 2021 12:33 PM
There's one of these parked on the apron at the Mid-Atlantic Air Museum in Reading,PA.
    May 2011
Posted by Real G on Friday, April 16, 2021 12:49 PM
Will you be doing a rescribe of the exterior, or will you carefully preserve the raised detail?  I ask because I have a Hasegawa Shin Meiwa US-1 that I am seriously considering keeping the raised panels lines and rivets.  The fit is bad, but mostly due to warpage.  There are resin sponsons that need to be integrated into the fuselage, plus some modifications to the windows and doors.  Looking at photos of the real plane, it is sweating rivets.
Anyway, I  look forward to seeing your Neptune take shape!
“Ya ya ya, unicorn papoi!”
    September 2012
Posted by GMorrison on Friday, April 16, 2021 1:54 PM
Thanks for posting your work. I'll be interested to see it come together.
That kit was one of the worst fitting kits I've built from a major manufacturer. In addition to the fuselage, the cowling were enarly impossible to get solidly aligned and mounted. Gear doors had little visible means of support.
I added the yellow escape panel frames on the underside of the cockpit greenhouse, added the throttle/ trim controls which are up there, and stained the top glazing Tamiya translucent green.
It is a really pretty aircraft. The was one on display at Moffett Field for a long time before it became a Federal Airfield and the thing disappeared.
Bill
    October 2004
Posted by ikar01 on Friday, April 16, 2021 8:03 PM
I remember that kit when it came out way back in the late 60s or early 70s, I think.
I rtemember taking the jet pods and using them for a AC-119 gunship.
I have only seen two or three operational aircraft and one of those was Japanese.
    April 2015
Posted by Wolfman_63 on Friday, April 23, 2021 8:48 AM
This week’s update on the 1/72 Hasegawa P-2H Neptune (P2V-7) I was able to get the fuselage together evenly after many hours of sanding and shaping. I then masked off the white sections and base coated it white. While it was drying I then assembled and detailed to radial engines and propellers.  After the fuselage dried the white areas were masked off. I then assembled the canopy and scratch built the overhead console. I used some spare photo etch levers and made some of the panels to match the reference photos. The canopy was them masked with kapton tape and installed. With the radial engines installed I then started to assemble the jets engines. The kit provides nothing to detail the exhaust of the jets. I dug through my photo etch extras and found a set of exhaust details and attached them.
The wings were then assembled and detailed. The fit of the wings was very good. I am working on completing the jet engines then a little masking on the landing gear bays and it should be ready to base coat the sea blue.
Website:
    April 2015
Posted by Wolfman_63 on Friday, April 30, 2021 6:46 AM
Work on the Neptune this week has been very tedious.  First, I had a lot of questions and comments on why I use kapton tape. So there are a couple of photos on removing the tape masks on the canopy. I then installed the landing gear. The nose gear did not have the landing light so I scratch built the housing from styrene rod then made the lens using acrylic gel.
Once I had all the base coat painting completed I started to do the decals. Since this kit was manufactured way back in the early 1970’s, the kit decals did not age well. I cut out a decal for the Japanese scheme to see how they would work. After soaking in warm water for over three minutes the decal started to slide. However, it then immediately broke apart. I took another one and coated it with Microscale decal film and let it dry. It still took a long time of soaking buy I was able to get the decal to stay mostly together. It required some very careful small movements to get it moved and placed on the spare surface. It was successfully placed. I decided that the only decal’s I was going to use off the sheet was the yellow rectangles for the tail. I then dug thru my spare decal binder and after an extensive search I located nearly all of the letters and numbers in the correct sizes as well as the US insignias. Surprisingly I found a decal for the propeller warning lines that was the correct size and looked more accurate than the kit decal. I then made the squadron logo decal that goes on the nose, the trident for the tip of the tail, and the “Jet Intake” decals.  Since each of the letters and numbers were individual decals it took a lot of time to get them placed and aligned. With all the decals placed I then started on the heavy weathering starting with the jet engines. The aircraft itself was sealed with a matte finish so that the weathering can be applied. I will be using three different shades of blue and two shades of gray to weather the aircraft with gray, black, and brown for exhausts.
Website:
    June 2017
Posted by fotofrank on Friday, April 30, 2021 8:10 AM
I had this kit when I first got back in the hobby. The plan was to build it up as Neptune Tanker 10, when it was based at Missoula International Airport. The more I studied my plan at that early stage of my return, the less I thought I was ready to extensively modify the kit to tanker status. When I can finds another kit, I may try to accomplish the mods and build Tanker 10. Tanker 10 is now the gate guardian at Missoula International.
OK. In the stash: Way too much to build in one lifetime...
    November 2020
Posted by Buckeye2 on Friday, April 30, 2021 9:06 AM
Looks great!  You don't see these built often.
    April 2015
Posted by Wolfman_63 on Saturday, May 8, 2021 9:12 AM
The 1/72 Hasegawa P-2H Neptune (P2V-7) is now complete! Before we get to the final photos there are a couple of details I needed to add. I first took a photo with the aircraft outside. Seems that different camera’s show the weathering differently but natural sunlight shows off the weathering better. Now on to the last detail, the nose has a frame that protects the crew member while giving him a place for his feet and legs instead of resting on the clear nose. The kit came with a small frame that looked nothing like the actual aircraft. I started with 30 AWG wire and cut 8 pieces. These were bent and tack soldered together. The nose frame was then painted and installed. I then used EZ-Line fine to add in the antenna.
With the aircraft completed, I am waiting for the brass nameplate before I can pack it up and ship it to the client. Seems the USPS is experiencing some delays and tracking keeps changing expected delivery day. Once it arrives I will post a few photos of it packed. The client purchased one of Grandpa’s Cabinets display cases. Once he has the display case and the aircraft together he will send me some photos and I will post them here. Thanks again for following along on this special build.
See more photos and details of this build from start to finish in my build log at https://davidsscalemodels.com/build-log/hp-2h-neptune-p2v-7/
Website:
Posted by jeaton01 on Sunday, May 9, 2021 7:16 PM
Sweet!
John
    April 2015
Posted by Wolfman_63 on Sunday, May 16, 2021 5:26 PM
Update - Just letting all know that the Aircraft was packed up with a brass nameplate and shipped to the client. It arrived without any issues. I also recommended to use one of Grandpa's Cabinets Display Cases. The aircraft will be presented to his Father on Father's Day.
All the final photos can be seen at https://davidsscalemodels.com/commissioned-work/1-72-hasegawa-p-2h-neptune-of-vp-4/
Website:
    August 2014
Posted by goldhammer on Sunday, May 16, 2021 9:13 PM
You and your client will put tears in his father's eyes with this one.
Very well done
    October 2019
Posted by Tanker-Builder on Monday, May 17, 2021 7:29 AM
Hi;
 The " Toon" was always one of my favorite NAVY birds. You have done one H$%% of a job!
    April 2015
Posted by Wolfman_63 on Friday, June 18, 2021 4:36 PM
One last update – The client presented it to his Father. Afterwards he left this comment on my blog:
“Thank you so much for all your hard work and effort on this. My father was incredibly surprised and even more excited to receive his plane. He immediately noticed the antenna you added and many of the other details you so expertly crafted into this. We spent the entire weekend talking about his time in the Navy, the squadron, and of course the plane itself. You helped make this a very special Father’s day. “
It was an honor to build this for a fellow veteran and having a Father and son to spend a special weekend together after being apart for a period of time due to pandemic situation.
Website:
