1/48 Hasegawa F-15E Dual Role Fighter
    April 2015
Posted by Wolfman_63 on Friday, May 14, 2021 9:04 AM
This next build is the Hasegawa 1/48 F-15E Dual Role Fighter. It is a commission build for the same client as my last one.  It will be built mostly out of the box but I will be adding an Eduard cockpit photo etch detail set. The first thing I noticed was the canopy and wind screen have a seam that runs down the middle. I sanded the seam down with 800 grit sand paper then went over it with 2000 grit. Once the seam was gone I polished them.
You can see what I use to removed seams and polish clear parts in the Tips and Trick section at https://davidsscalemodels.com/tips-and-tricks/how-to-repair-clean-and-polish-clear-parts/
I then started on the cockpit. The ejection seats were detailed with the photo etch accessories and some spare decals for the labels. The cockpit tub was then detailed with photo etch side panels. The instrument panels were then sanded down so that the photo etch accessories could be added. The cockpit tub was then assembled and installed into the front section of the fuselage. I cut off the HUD glass mount as this will later be replaced with a more accurate photo etch replacement. Starting on the rest of the fuselage and the exhaust cans.
See more photos and details of this build in my build log at https://davidsscalemodels.com/1-48-f-15e-dual-role-fighter/
Website:
David's Scale Models - https://www.davidsscalemodels.com
Posted by keavdog on Friday, May 14, 2021 7:09 PM
Pit looks great.  Nice work on the canopy.  Not sure how junior modelers would deal with those pesky clear part mould lines.
Thanks,
John
    April 2020
Posted by Eaglecash867 on Friday, May 14, 2021 8:30 PM
Looking good so far, Wolfman!  Not to be a rivet counter or anything, but F-15 seats don't have the ejection handle between the legs. Wink
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
    April 2015
Posted by Wolfman_63 on Friday, May 21, 2021 3:21 PM
 The build of the F-15E Dual Role Fighter is moving forward. I assembled the exhaust cans. The detail on them is very good. The kit even comes with photo etch parts for the turkey feather rods and control links. I painted the turkey feathers section using Vallejo’s Metal Color Jet Exhaust. It gives them a nice burnt metal finish. The base ring of the exhaust cans were then painted with Metal Color Steel. For the inside I used light gray, dark gray, and black pastel chalk. The outside I used dark gray, brown, and black then used blue and brown on the base ring. The intake vanes were painted Metal Color duraluminum with the intake ducts painted white. I was able to get the seam between the intakes halves filled with putty. Once the intakes were installed I assembled the main part of the fuselage then installed the forward section and the wings. The fuselage was then base coat painted with FS36118 (gunship grey).
I then started on the centerline tank and weapons. The kit CBU’s lacked detail. Looking thru my spare parts drawers I found some Eduard Brassin resin CBU’s and opted to use these instead of the kit ones. I am currently working on all the weapons. The aircraft will be armed with the CBU’s, 4 sparrow missiles and 4 sidewinder missiles
Website:
    January 2020
Posted by wpwar11 on Friday, May 21, 2021 5:54 PM
Hey Wolf,
I'm building a Hasegawa 1/48 Strike Eagle.  I think the construction for all the 1/48 F15's is the same.  Did you have a problem with the intakes?  I need to clamp together the fuselage half for no gap for parts A5 and A6.  Also, the intake trunks needed sanding to remove the locator pins.  You can see the pins as you look down the intake.
just curious
The exhaust cans look awesome
    January 2020
Posted by wpwar11 on Friday, May 21, 2021 6:04 PM
Eaglecash867
how interesting.  My kit (Hasegawa F15E Strike Eagle 1/48) calls for these handles in that position.  So maybe fill the holes and omit the handles?
    April 2020
Posted by Eaglecash867 on Friday, May 21, 2021 6:11 PM
wpwar11
how interesting.  My kit (Hasegawa F15E Strike Eagle 1/48) calls for these handles in that position.  The forward seat is assembled so close to control stick you can't assemble the ejection handle. Wont it look odd only on the RIO seat?  So maybe fill the holes and omit the handles?
Neither seat in any F-15 has ejection handles in the center of the seat.  Just leave the handles off and fill the holes.  Between the A-10, F-15, and F-16 ACES II seats, only the F-16 seats have handles in the center.  F-15 and A-10 seats both have canopy breakers above the headrest, while the F-16 seats don't.
    August 2015
Posted by crown r n7 on Friday, May 21, 2021 6:42 PM
That f-15 is looking good. I have built a few of the hasegawa kits they can be a bit fussy.
 Nick.
    April 2015
Posted by Wolfman_63 on Saturday, May 22, 2021 2:31 PM
wpwar11
Hey Wolf,
just curious
Yes I think they are all the same mold. Well at least this kit appears to be their F-15D with some extra parts to make it look like an E. This is the clients kit he supplied. I think he bought back when it was first release and had it sitting in storage.
I did not need to clamp the fuselage together but did add some styrene to even out the intakes. I did not remove the locating pins. I used a stick to put putty on top after mounting then sanded flush and a quick shot of paint.
Website:
    April 2015
Posted by Wolfman_63 on Friday, May 28, 2021 6:11 AM
 The F-15E build continues. This week all the bombs and missiles were assembled, painted and decaled. Starting with the bombs, these were painted drab with aluminum fins. They were then mounted on the racks. The AIM-7 missiles were then painted. For the AIM-9 missiles I cut the tips off and made the sensor head out of clear acrylic gel and painting them with Tamiya X-19 smoke. You can see how to do this in the Tips and Trick section at https://davidsscalemodels.com/tips-and-tricks/how-to-make-laser-and-ir-sensor-heads/
 Next I worked on the exhaust area by painting it with the Vallejo duraluminum Metal Color and weathering it with some blue, brown and black pastel chalk. The landing gear and tails were then installed. The kit decals are very brittle and yellowed due to being in storage for so long. I looked thru my decals sets and found a set of Afterburner Decals set (# 48-031). These are F-15E Strike Eagle flagships from the 366th FW at Mountain Home AFB, Idaho. I will be doing the F-15E 87-0210 366th WG CO aircraft 2003. This aircraft features the "Let's Roll" decal on the left front fuselage.
I am in the process of applying the many, many stencil decals then on to the specific aircraft decals.
See more photos and details of this build from the start in my build log at https://davidsscalemodels.com/1-48-f-15e-dual-role-fighter/
Website:
Posted by Tojo72 on Friday, May 28, 2021 8:59 AM
Your doing a great job,I built that back in the early 2000's did the green scheme.That is some payload that thing carries
    January 2020
Posted by wpwar11 on Monday, May 31, 2021 2:58 PM
It is looking really good.  Funny thing.  I'm building a Hasegawa F15E with the same exact decal sheet.
    April 2015
Posted by Wolfman_63 on Friday, June 4, 2021 2:36 PM
The Eagle is complete! I finished applying the decals and then installed all the weapons.  The canopy was polished , detailed and painted. Earlier I trimmed off the kit HUD and replaced it with a photo etch version using clear acetate film for the HUD glass. The canopy was then mounted in the open position. I did a final weathering of the exhaust and some detail painting to complete the aircraft.  As for the kit, back in the day Hasegawa rushed the F-15E kit to the market by taking their F-15D and adding some “E” parts. While the kit resembles the “E” version it is not quite accurate to the real aircraft. Aside from the aftermarket decals and photo etch accessories this client supplied kit is straight out of the box.  The fit is very good and the instructions are laid out well. I cannot comment on the kit decals as these did not age well. The aircraft now needs to be carefully packed up and shipped to the client. Thank you for following along!
Website:
    April 2020
Posted by Eaglecash867 on Friday, June 4, 2021 3:34 PM
Nice looking Mud Hen, Wolfman!
    April 2015
Posted by Wolfman_63 on Friday, June 11, 2021 4:51 AM
The F-15E Dual Role Fighter was carefully packed up with a CD of all the build photos (always included in commission builds) as well as a brass nameplate. Two days later it arrived at the client’s home with no issues. He then placed it and the nameplate in one of Grandpa’s Cabinet display case. He is extremely happy and proudly displays it.
You can see all the final photos in my Commissioned Work section at https://davidsscalemodels.com/commissioned-work/1-48-hasegawa-f-15e-dual-role-fighter/
Website:
