question on interior colors for WW2 US aircraft
JCM
    September 2021
Posted by JCM on Wednesday, September 15, 2021 7:05 PM
After reading the most recent issue describing the building of an Avenger and having done some reading on various WW2 U.S. aircraft, have a question on interior colors.  Specifically wheel wells and cowling of US Navy aircraft.  What source is there that notes that they were Yellow Zinc Chromate or interior green?  Did the US Navy have a systematic program in painting, specifically wheel wells, landing gear?  Or was it more haphazzard at the time?
When you look at the pictures in the recent issue on the Avenger, the author, while not specifically noted, painted the wheel wells white like the aircraft underside.  And in reading various reference books and looking at pictures, the wheel well (including struts) colors suggest variations over the war years.  Have seen pictures where the aircraft are overall gloss sea blue including the landing gear and maybe the wheel wells and interior doors are also sea blue.
    June 2021
Posted by rocketman2000 on Thursday, September 16, 2021 8:48 AM
There were indeed variations.  Sometimes by manufacturer.  This was often with secondary contract builders, like GM or Ford when they built aircraft.  I think maybe that would be a good article for FSM if they can find someone able to write it.
    May 2006
Posted by Shipwreck on Thursday, September 16, 2021 8:49 AM
JCM, you may find this 3 part series helpful: http://www.ipmsstockholm.org/magazine/2004/01/stuff_eng_interior_colours_us.htm
On the Bench:
Revell 1/96 USS Constitution - rigging
Revell 1/48 B-1B Lancer Prep and research
Trumpeter 1/350 USS Hornet CV-8 Prep and research
JCM
    September 2021
Posted by JCM on Thursday, September 16, 2021 2:12 PM
Thank you.  The information was very informative.  At least I don't have to be so goofy when it comes to the interior.
    July 2004
Posted by stikpusher on Thursday, September 16, 2021 3:53 PM
JCM
USN WWI aircraft usually had the wheel wells and landing gear painted to match the adjacent areas. So light gray on the early war Blue Gray/ Light Gray scheme, White on the mid to late war Tri Color schemes, and Sea Blue on the late war scheme. But... there's usually a but... due to sub contractors and parts being stocked for long running production, it was not unusual to see previous color scheme parts like wheel hubs on new production aircraft due to overlaps. So white wheel hubs on overall gloss sea blue aircraft, or light gray or blue gray hubs on tri color scheme aircraft. Your best bet is to try and find photos of the aircraft you're actually modeling.
Also, wing fold areas are usually painted in an exterior color, not interior green or zinc chromate. Period photos prove this is the rule, not the exception.
Thats a dirty white in the photo below, not zinc chrimate or interior green.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    July 2004
Posted by stikpusher on Monday, September 20, 2021 5:29 PM
Found this great original color photo of a TBF. Note the gray landing gear and blue gray exposed wing fold area
       - Plankton
LSM
    July 2004
Posted by stikpusher on Wednesday, September 22, 2021 1:43 PM
A good exception to the adjacent external colors being used in the wing folds and landing gear areas- the SB2C Helldiver. Interior Green in those areas, as well as the bomb bay
       - Plankton
LSM
    January 2020
Posted by Space Ranger on Monday, September 27, 2021 2:09 AM
The Erection and Maintenance (E&M) manuals for the various aircraft types usually list the colors for those areas.
    May 2006
Posted by Shipwreck on Monday, September 27, 2021 1:07 PM
JCM, you might find all the good responses to your original question a bit confusing. There were rules; but the manufactures bent the rules, as needed, to get the job done. The real answer is to track down a photo of your plane that shows its colors. Without an original photo you can be creative; or you can stick with the standard which it should be! I is your model.
On the Bench:
