1/48 Tamiya Fw 190D-9 - Final Flight of Chevron Dot (Complete)
    July 2019
Posted by Hoss WA on Tuesday, September 21, 2021 10:13 PM
Continuing on my Dora theme, I found another interesting scheme to attempt, this time using Tamiya's kit. This aircraft, W.Nr. 211934, was one of three Fw 190D-9's that flew to Fürth, Germany to surrender on May 8, 1945.
It's exceptionally well documented in both black & white and color photos as well as some movie film of the "surrender" scene, where an unidentified pilot exits the plane into the custody of US troops.
The camo scheme is unique, particularly on the wings, with unusually shaped areas of RLM 75, 81 and 82. Previous markings are painted out with markings for the Stab II./JG 6 Technical Officer applied.
Compared to the Eduard kit, the Tamiya model builds itself. Although there are a few well-documented inaccuracies, it still looks fine and is fun to build, especially for a 25-year-old kit. It's OOB with the addition of brass tubes for gun barrels, Eduard seat belts and decals from Eagle Editions.
Here's the office - not very detailed, but not very visible either.
Mr. Color paints were used for the main camo. Mr. Finishing Surfacer was used for primer.
I've attempted a number of new techniques for me on this build. First, convinced by lawdog's results, I took a crack at AK worn effects fluid over silver paint on the wing roots to simulate chips and scratches. I'm impressed with how this turned out. More photos later.
Second, I used some scotch brite as a template for randomized pre-shading. I'm happy with how this worked but I think it was most effective for the lighter colors and not the darker colors.
Third, I tried the "salt" shading technique to weather the prop and think it came out OK. I could have been more bold with the contrast, but it's a good start. I'll put some photos in a later post.
Since there are so many photos of this aircraft from many angles, I've tried to replicate the coloring and camo pattern as closely as possible. I've had to rework the camo details quite a bit on the fuselage sides and tail, but i think it's fairly close at this point. I'll post some comparison shots from various angles when it's complete.
The main camo for the wings was applied using paper templates and the fuselage was all freehand. Gloss coat is now on and decals are next.
Thanks for following along.
    July 2019
Posted by Hoss WA on Tuesday, September 28, 2021 7:26 PM
Chevron Dot has completed its final flight from my workbench to the photos.
The decals went on with no problem followed by a gloss coat. For the first time I tried an oil wash for the panel lines instead of the usual Flory wash. The drying time is longer, but I liked the effect with bolder colors. I also did some panel fading with oils to experiment in changing the color slightly.
After a matte coat, I applied a number of weathering techniques - black-brown mix, pencils, pastels, more oils, a light mist of deck tan and light earth over the entire airframe, etc.
The original photos show the plane was particularly dirty and muddy when it landed and I tried to capture that by spending quite of bit weathering focus underneath the wings and fuselage.
I also tried Infini Aero rigging for the antenna cable and it's a winner. EZLine is out becuase it's thicker and actually has a flat profile.
Here are some comparison photos vs. the originals.
The Tamiya kit looks good but it's not nearly as detailed as the Eduard kit as far as surface detail, riveting, etc. Still pretty good for a 25-year old kit.
I like the various areas with red oxide primer. They give the airframe some character.
The interesting photo below shows Chevron Dot (right) meeting its demise on the trash heap. The primed areas and unique wing pattern and coloration are clear.
I used a combination of Eagle Cals and Kommandeur decal profiles for the camo pattern.
I decided to close the canopy on this one to show the lines of the Dora and give some tension to the antenna cable.
Overall, it was a fun project to test out some new weathering techniques.
I'm happy with how it turned out and think the overall rendition hits the mark. However, I think I could have dirtied it up a bit more after looking more closely at the photos. I find it's always a challenge to have just "enough" weathering applied and I usually tend to go lightly to avoid overdoing it.
Thanks for looking. Comments and critique always welcome.
fox
    January 2007
Posted by fox on Tuesday, September 28, 2021 10:34 PM
Very nicely done Hoss. Toast Toast Toast Even the photos are outstanding. My "tests" never turned out looking that good.Wink
Jim Captain
Stay Safe.
 Main WIP:
Posted by jeaton01 on Tuesday, September 28, 2021 10:51 PM
Very well done!
John
    July 2021
Posted by Flight Line Media on Thursday, September 30, 2021 4:11 AM
You certainly did an excellent job on your work, Hoss. Thanks for sharing it.
Andrew
www.flightlinemedia.co
Follow us on Instagram: from.the.ariel.view
    July 2019
Posted by Hoss WA on Sunday, October 3, 2021 10:02 PM
fox
Jim Captain
Stay Safe.
Thanks Jim. Much appreciated.
    July 2019
Posted by Hoss WA on Sunday, October 3, 2021 10:03 PM
jeaton01
Very well done!
Thanks jeaton.
    July 2019
Posted by Hoss WA on Sunday, October 3, 2021 10:04 PM
Flight Line Media
Thanks Flight Line. Much appreciated.
    November 2003
Posted by tempestjohnny on Monday, October 4, 2021 4:51 AM
Hoss you mastered this one. Camo and weathering are great.
    July 2019
Posted by Hoss WA on Sunday, October 10, 2021 6:26 PM
tempestjohnny
Thanks Tempest. I had fun with this one.
    May 2004
Posted by cbaltrin on Sunday, October 10, 2021 8:00 PM
Masterful paint job you've done there. Very nice Bow Down
On the Bench: Too Much
    July 2019
Posted by Hoss WA on Saturday, October 16, 2021 9:10 PM
cbaltrin
Thanks cbaltrin. Much appreciated.
