The Original 'Egg' plane - Messerschmitt Me163 'Komet' (Testors/ ex-Hawk 1/48)
Posted by gregbale on Friday, October 1, 2021 12:30 PM
This early-'80s re-release of the early-'60s-vintage Hawk kit is almost universally trashed (particularly in comparison to the Trimaster kit, which appeared some 30 years later); in fact it's just a product of its time, a fairly decent basic shape lacking in any real detail. Since it is actually such a simple airframe, this is by no means the disaster the more rabid of the modeling pundits would have you believe. If one were to choose to scratchbuild a super-detailed cockpit -- since a poor pilot and seat are the only interior features provided in the kit -- the Komet's spare cockpit would perhaps be the easiest cockpit I know of (including aircraft of both world wars) to reproduce. By far the worst part of the kit is the canopy, which has a thickness common to kits of this vintage, and has the frame lines of the distinctive armor-glass panel...which was a separate piece on the real aircraft, mounted on the shroud above the instrument panel...inscribed on the interior of the canopy. It also has a weird, 'wavy' molded shape on the canopy's inside surface which is quite impossible to fix or hide short of vac-/stretch-forming another one. (However, since I was planning on leaving the canopy closed, I just painted the frame and added a clear piece for the armor glass fitted inside; through the thick canopy, it actually looks okay.)
I got the LoneStar Models resin set for the cockpit because it was cheap and available at the time. Molding was only so-so and had a sort of pebbly texture which I didn't fully recognize until it was under paint. I left it as-is. Fit was also less than perfect for a set supposedly designed for this specific kit, with a fair amount of resin removal required on the underside of the cockpit tub.
The kit had an option for making the landing skid extendable, which for ease of construction I ended up gluing in place---right before I found the paragraph online that explained the skid was usually 'sprung' even when the dolly-wheels were attached, and that the oft-seen photos of a/c with the dolly wheels on and skid retracted are a common museum sight, but rare on an operational one, Ah, well.
Kit-supplied markings were used for “White 54,” a Me 163B of 6./JG400 based at Husum in Schleswig-Holstein in May, 1945. My guess for the scheme was 81/83/76 with 81/83 mottling. [It was after painting that I found info showing that the famous and oft-repeated photos of “White 54” are in fact that aircraft's tail-fin on another airframe...probably “White 14”...after the whole batch of captured aircraft had been returned to the US for evaluation after the war. Apparently the tail of “White 54” made a number of 'guest appearances' on other fuselages at that time, for photographic purposes.]
These ancient kits can be liberating, particularly as a break between 'major' projects. They can usually be had cheaply, are great for experimenting or trying out new products or techniques...and will benefit from pretty much any care and attention one may choose to lavish on them. Less pressure, more fun.
Hope you enjoy.
Greg
George Lewis:
Posted by keavdog on Friday, October 1, 2021 12:49 PM
Well you surley did a fine job an old kit.  Your finish/camo is awesome.  Well done.
Thanks,
John
    April 2015
Posted by Mopar Madness on Friday, October 1, 2021 12:53 PM
Beautiful work on a vintage classic! For its time this was a beauty of a kit.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    July 2004
Posted by stikpusher on Friday, October 1, 2021 1:10 PM
YesYes That looks damn good! Especially when you consider the vintage of the kit.   it may not be a contest best of show candidate, but sitting with the rest of a 1/48 Luftwaffe it will make a fine addition! Bravo!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    October 2004
Posted by ikar01 on Friday, October 1, 2021 1:23 PM
I remember when that and the Japapese Baka came out.  They both had a orange transpatent flame that you could glue into the engine exhaust.
    May 2011
Posted by Real G on Friday, October 1, 2021 1:41 PM
Yep, great job on an old kit!  YesYes
It is easy to find faults with it here in the 21st century, but when it came out, late war Luftwafffe kits were thin on the ground.  I was just talking to a friend about how the Lindbergh 1/72 kits like the Ar-234B, He-100D, and He-162 were pretty much it back in the 1970s.  As a kid, I really like their 1/48 Me-262 with retactable landing gear.  I remember being over the moon when Monogram came out with their 1/48 Do-335A-0 in the 1970s.
In the late 1980s/early 1990s, Volks released a number of "Luftwaffe 1945" resin kits in 1/48, from the small He-162 all the way to the He-219.  They looked fabulous, but were terribly expensive.  Then Trimaster started the tidal wave with their hi-tech kits, including the Me-163.  And now we are spoiled for choice, with modern kits of the Komet in 1/144 (Brengun), 1/72 (Academy), 1/48 (Gas Patch), and 1/32 (Meng).
“Ya ya ya, unicorn papoi!”
fox
    January 2007
Posted by fox on Friday, October 1, 2021 1:56 PM
Very nice build Greg! Yes
Jim Captain
Stay Safe.
 Main WIP:
Posted by gregbale on Friday, October 1, 2021 2:09 PM
Thanks, guys!
ikar01
I remember those as well. Unfortunately, Testors didn't include that in the reissue. Big Smile
Greg
George Lewis:
Posted by Gamera on Friday, October 1, 2021 5:54 PM
Wow, now that's a blast from the past! I remember the yellow edged Testor's/Italeri kit boxes back in my youth very well.
Great job there Greg- I love the camo! Esp on an aircraft so small it couldn't have been easy to paint. It came out beautifully!! Heart
Posted by gregbale on Saturday, October 2, 2021 5:53 AM
Thanks, Cliff!
I also have quite happy memories of those yellow-edged Testors boxes. They were among the first I recall seeing that would have 3 or 4 photos of the completed model on the back panel...which really got the jones going to start the kit as soon as you got it home!
I think they may also have been my introduction to Italeri (or 'Italaeri,' as it was then) kits, back before they were importing to the US in a major way under their own label.
Cheers
Greg
George Lewis:
    July 2021
Posted by Flight Line Media on Sunday, October 3, 2021 7:26 PM
You certainly did an awesome job on your build, Greg! Thanks for sharing it.
Andrew
www.flightlinemedia.co
Follow us on Instagram: from.the.ariel.view
Posted by gregbale on Sunday, October 3, 2021 7:43 PM
Flight Line Media
Thanks, Andrew! Beer
Greg
George Lewis:
    June 2017
Posted by Chemteacher on Sunday, October 3, 2021 8:01 PM
Hey, awesome job. I remember that kit as a kid but I never purchased one. Great job. Your camo looks 1st class.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Monday, October 4, 2021 12:22 PM
EGGCELLENT
Well............
             someone had to say it.
The camo is beautifully
         "scrambled"
               and
      "well done" too.
 https://i.imgur.com/LjRRaV1.png
