Converting Tamiya F4F-4 to a F4F-3
    January 2017
Posted by cadman on Sunday, November 21, 2021 10:38 AM
Hello, I wanted to ask you experts out there on the F4F aircraft what would I have to do to convert the Tamiya Kit F4F-4 To a F4F-3 with out buying any after market items. I know about removing one of the machine guns and ammo panel on each wing and changing the pilot tube with some wire. I do not care about the engine or interior so much. I am wanting to do a F4F-3 at midway.
Thanks, George
Posted by jeaton01 on Sunday, November 21, 2021 11:13 AM
The wing panel line and the gun arrangement is different, as the wings did not fold.  There were several different cowling scoop arrangements for the -3 Wildcats.
John
Posted by gregbale on Sunday, November 21, 2021 11:51 AM
As John pointed out, the non-folding versus folding wings is the biggest difference. Aside from the engine itself, the differences in scoops...and number and arrangement of cowl flaps...were also distinctive.
You might do well to compare the line-drawing profiles and other illustrations on this page:
https://weaponsandwarfare.com/2020/05/28/grumman-f4f-wildcat/amp/
I did the same conversion you're looking at with the Revell F4F-4 some years ago. Not terribly difficult...but a lot of rescribing of panel lines! Big Smile
Good luck.
Greg
George Lewis:
    August 2021
Posted by goldhammer88 on Sunday, November 21, 2021 2:44 PM
Depending on what scale you want, and how much time you want to invest getting to how accurate you want it.  If 1/32 would work for you, take a look at the -3's from Trumpeter.  Well designed, And the engines are pretty well detailed oob.  Not really that spendy, and IIRC, they have both early and late versions.
    August 2009
Posted by cvsusn on Sunday, November 21, 2021 11:14 PM
George,
As a heads up, Eduard is coming out with a limited edition F4F-3 for the Battle of Midway.
https://www.scalemates.com/kits/eduard-tba202206-grumman-f4f-3-wildcat-battle-midway--1379231
June 4-6 will be the 80th anniversary. Maybe look for it around April? Just a scientific wild a$$ guess.
Carl
    July 2004
Posted by stikpusher on Monday, November 22, 2021 10:46 AM
Just for clarification, the US carriers at Midway had F4F-4s in their air groups, while only a half dozen or so F4F-3s were on Midway air station with VMF-221. If you're planning to build one of the carrier based Wildcats, you'll need a -4.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2017
Posted by cadman on Monday, November 22, 2021 3:16 PM
Thanks for the info. I wonder what markings the plane will have? Eduard are great kits.
George
