Dora Wings P-43A Lancer 1/48
    January 2015
Posted by Aggieman on Monday, December 6, 2021 5:06 PM
I have completed what likely is my last build of the year, a member of the Thunderbolt family, the P-43A Lancer.
Let's call this one ... Dad.  Grandpa is Seversky's P-35.  And the son is the much more famous P-47 Thunderbolt.
This kit was a first for me in a couple of ways.  First time I've built a Lancer.  First time I've tackled a Dora Wings kit (with 2 more in the stash).  I admittedly don't have a lot of background on the P-43, but aside from its family geneology, I do know that the Lancer really didn't serve with any US units other than in a training capacity.  The reasons for this seem to point toward its under-performing in the role for which it was intended and perhaps an under-powered power plant.  Like the P-35, other countries used the Lancer in active units, although I never found much on whatever its exploits may have been.
Now to the kit.  Overall it is a good kit, but oh my, it was quite an adventure to get to the finish line.  The instructions are hot garbage.  And I do mean smelly hot garbage.  Parts location is spotty at best - just an arrow pointing to a general location for many of the smaller parts.  Online references were out there, but I didn't find any to the level of detail that I needed.  In some cases I opted to leave certain interior parts off.
The kit comes with a PE fret that I felt was a bit on the thick side.  As a result, I was not able to properly bend the lap belts.  I left them off rather than having the clearly resting in open air over the seat.
There were some parts that did not seem to include enough as per the awful instructions, or too many.  If the former (certain engine parts), those got left on the sprue.  If the latter, I used whatever I needed and discarded the remainder.
There are no locator pins on this kit.  But if one takes their time, it actually goes together rather nicely.  I only encountered one obvious mis-alignment, under the rear portion of the canopy; that one was easily sanded down and concealed beneath the canopy.  Otherwise I had seams typical of a Monogram kit that were easily dealt with.
When I dry-fitted the canopy, I initially thought it was one of the best fits I'd ever seen on a kit not coming out of Tamiya's (or similar) production line.  But when I got it glued into place, the fit was not at all good.  The rear non-moving portion of the canopy was properly aligned to the fuselage, but the center portion did not meet correctly.  One side was inline with the rear, while the other was not.  As the center piece would slide back during operation, it seems to me it should have not been flush anywhere with the rear piece.  To top things off with the canopy, after it was set and not going anywhere without risking damage to the canopy parts, I realized I had neglected to put the pilot's head rest into place.  I opted not to risk clear parts damage to get that head rest into place.  Luckily it's not really that easy to notice the missing head rest.
I painted with mostly Vallejo colors - US olive drab and US neutral gray, although there is some AK Interactive XTreme Metallics and Mission Models colors in use as well.  Decals performed very well.  I opted to build this as a new Lancer with very little weathering (I did put down some dirt wash on the engine crank case).
And how about a family portrait?
Two Tamiya -47s and one Monogram Pro-Modeler -47, the DW -43, and a Hobby Craft -35.
Next up is another first-time kit for me, Meng's Me163 in 1/32.  I doubt I'll be able to complete that one prior to the end of the year, but one never knows.
Posted by keavdog on Monday, December 6, 2021 7:35 PM
Nicely done.  I've wondered about Dora Wings kits - they have some nice subjects.  Great collection you have there.
Thanks,
John
Posted by jeaton01 on Monday, December 6, 2021 11:34 PM
I was hoping that kit would go together better, that's not a happy sounding trail you just went down.  Guess I'll stick with the Classic Airframes kit that's in the stash.  In the end you made it look good, though, Stephen.
John
    January 2015
Posted by Aggieman on Tuesday, December 7, 2021 7:57 AM
Thanks John.
DW does have some good subjects that you don't find elsewhere.  They are short-run style kits, though, so you have to determine if that's something you want to deal with if you are going to pick up any of their offerings.
I have a P-63 and a Marcel-Bloch MB.151.C-1 that I found interesting enough to add to the stash, so we'll see how those go.
    January 2015
Posted by Aggieman on Tuesday, December 7, 2021 7:59 AM
jeaton01
  Thank you John.  As for the DW kit quality, I'll just say that it was not nearly as good as I might have hoped for, but I've also trashed much worse than this one.  It is buildable, and it's certainly possible that I screwed stuff up along the way.  The instructions are awful, however, and the parts count not matching what the instructions called for was simply baffling.  Perhaps my next DW builds will go a little better.
    September 2006
Posted by the Baron on Tuesday, December 7, 2021 8:28 AM
Nice build, Stephen!  Even with the issues you pointed out-you overcame them pretty well.
I've seen other posts around the web about this kit, with a consensus that it's not a shake-and-bake.  I have one in my stash, too, because as we've noted, the only other 1/48 scale kit was the Classic Airframes kit.  And Dorawings is kitting subjects seldom or maybe never seen kitted, too.  But you give us a good heads-up on tricky areas.
    June 2021
Posted by rocketman2000 on Tuesday, December 7, 2021 9:14 AM
I like Dora Wings, and am interested in building the Lancer.
I like the fact that D W includes some extras of very small parts- I wish more kit makers did.  I think the lack of locating pins is an eastern european thing.  Don't know where D W is located though.
    January 2015
Posted by Aggieman on Tuesday, December 7, 2021 9:50 AM
rocketman2000
Their web site indicates they are in the Ukraine.
There are many small parts that made me think they were attempting Tamiya 1/32 level detailing at the 1/48 scale.
    January 2015
Posted by Aggieman on Tuesday, December 7, 2021 9:53 AM
the Baron
Thanks Baron.  I do really like that they put out rare subjects like this Lancer.
Posted by Gamera on Tuesday, December 7, 2021 11:19 AM
Great job you did on her Aggieman!!! Heart
I'd wondered about the Dora Wings kits. I've built a few Classic Airframes kits- guess they're pretty close to the same thing.
    September 2006
Posted by the Baron on Tuesday, December 7, 2021 1:04 PM
Yeah, I really look forward to the release of their Vultee Venegeance.  I think they plan to release it before Christmas.  I also want to build some of their other, recent releases.  It's an interesting catalog of subjects.
Posted by waikong on Thursday, December 9, 2021 11:26 PM
 maybe the CA kits will come done in price on ebay,, they were way too high for me.
    September 2006
Posted by the Baron on Friday, December 10, 2021 7:56 AM
waikong
When Dorawings issued its P-43, I noticed prices for the old CA kit come down a bit on eBay.  I used to see auctions with a starting bid of $100 or more, but after the Dorawings issue, the starting bids were about half that.
    July 2019
Posted by Hoss WA on Friday, December 17, 2021 3:28 PM
Nice! I never heard of the P-43 Lancer until now. Thanks for the history. Thanks also for the info about the kit. Looks like you made it though the build - really looks nice. Congrats.
    June 2021
Posted by rocketman2000 on Saturday, December 18, 2021 9:01 AM
Looks great!  It is on my shopping list now.
    January 2004
Posted by ChrisJH666 on Friday, April 1, 2022 2:52 AM
I have the Classic Airframes kit part built, and trust me, to get it right takes a fair bit of work, though, to be fair, I am adapting it to have the cockpit open, which takes a fair bit of remodelling of the fuselage, and a lot of scatchbuilding in the cockpit. Might actually try to progress things a bit more soon. Got to the point of replacing the half relief exhaust pipe in the belly with something a little more substantial.
In the queue: 1/48 Beech Staggerwing (RAAF), P38 (RAAF), Vultee Vengeance (RAAF), Spitfire Vb (Malta), Spitfire VIII x2 (RAAF), P39 x2 (RAAF), Martin Baltimore (Malta?), Martin Maryland (Malta), Typhoon NF1b, Hellcat x2 (FAA)
Chris
