Thanks kik36 ,fightnjoe ,falcon039 ,cassibil ,72cuda ,ChrisB , J-Hulk ,
nsclcctl ,stinger ,monrad and rjkplasticmod.
nsclcctl , first I painted all the green parts flat black ,then misted it
with the interior color ,lastly ,I lighted the color a little bit with yellow
and misted it on the most worn parts.
All this was done keeping the lower parts of the cockpit in a darker
shade to simulate shadows.
Then a little drybrushing.
stinger , the throttle levers are very easy to make.
I cyanoed fine gauge soldering wire(any wire the right size is ok)
to the throttle quardrant and to the gear switch.
Then blobs of Gunze Mr Surfacer 500(any putty or white glue is ok)
are placed.This is followed by painting .
rjkplasticmod , yes the gear bays were tricky but brute force came
to the rescue.Also there were a few gaps that needed to puttied.
Here is a little update ,the cockpit has been installed.
