P-39 Question
    January 2004
P-39 Question
Posted by ChrisJH666 on Wednesday, April 13, 2022 8:03 AM
I'm thinking of building a 1/32 P-39D or F, but my options seem to be the Revell D model, or the Eduard(which I would prefer) Q model or P-400. Could anyone advise on the differences between the different models, and on the quality of the kits, especially the Revell offering? I know about the smaller cannon on the P-400, but what other differences were there visually or in the cockpit between the models?
In the queue: 1/48 Beech Staggerwing (RAAF), P38 (RAAF), Vultee Vengeance (RAAF), Spitfire Vb (Malta), Spitfire VIII x2 (RAAF), P39 x2 (RAAF), Martin Baltimore (Malta?), Martin Maryland (Malta), Typhoon NF1b, Hellcat x2 (FAA)
Chris
    May 2020
Posted by learmech64 on Wednesday, April 13, 2022 8:18 AM
Hey Chris, without any references Im dont know the finer differences between the different models. You do have at least 2 additional choices in kits. There is the Special Hobby and Kitty hawk kits in addition to the ones you mentioned
Doug
    July 2004
Posted by stikpusher on Wednesday, April 13, 2022 9:42 AM
The three main external visual differences on types will be armament, exhaust stacks, and propellor type. Even among the D series there will be armament variations into the nose cannon. Besides the P-400, the D-1 and D-2 used the 20mm nose gun. Exhaust stacks can be six or twelve per side, and on the six per side type can vary between standard round type or "fishtail" type. Wing armament on most versions was two .30 caliber guns in each wing, except for the Q, which deleted the internal dual .30 caliber guns from each wing and instead had single podded .50 caliber guns under each wing. Propellors were increased in diameter and blade width as variants were introduced. Check your specific aircraft and sub type for details of that version.
http://www.airvectors.net/avp39.html
http://www.joebaugher.com/usaf_fighters/p39.html
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2015
Posted by Aggieman on Wednesday, April 13, 2022 11:13 AM
I built the Revell P-39 a few years ago.  It is a wonderful kit (especially when augmented with the Eduard BigEd PE set).  It is also a repop from the Special Hobby kit.
https://www.scalemates.com/kits/revell-04868-p-39d-airacobra--154821
    January 2004
Posted by ChrisJH666 on Wednesday, April 13, 2022 3:13 PM
Thanks, I wasn't aware of those two
Chris
    January 2004
Posted by ChrisJH666 on Wednesday, April 13, 2022 3:19 PM
Thanks. I have a reasonable knowledge of the P-39, but I was not aware of some of that, especially that some early D's had the 20mm, and the differences in props. Mine will be one of the couple of dozen used by the RAAF, and I have Red Roo's book on them on the way.
Chris
    July 2004
Posted by stikpusher on Wednesday, April 13, 2022 5:49 PM
Well that's a new one to me. I had no idea that the RAAF had used the Airacobra. Here is a link to some info on the type in RAAF service, complete with photos and individual aircraft records.
https://www.destinationsjourney.com/historical-military-photographs/bell-p-39-airacobra-in-raaf-service/
       - Plankton
LSM
    September 2005
Posted by richs26 on Wednesday, April 13, 2022 6:37 PM
Here is an easy to use chart showing the obvious differences between versions.  Just disregard it being based on Eduard's 1/48 P-39s.
http://www.clubhyper.com/reference/p39variantsms_1.htm
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    January 2004
Posted by ChrisJH666 on Thursday, April 14, 2022 4:39 AM
That's brilliant. Thanks.
Chris
