Sukhoi Su-27 Flanker B Trumpeter Scale 1:32
    January 2015
Posted by arb65912 on Friday, May 20, 2022 3:02 PM
Sukhoi Su-27 Flanker B Trumpeter Scale 1:32 and what triggered this post and my presence here in forums.
I work with my friends on models for X-Plane flight simulator.
I will be working on the SU-27 UK for the mentioned above simulator and in order to make a realistic 3D model, I needed some materials more than just pictures as pictures do not show the details and the way aircraft is built.
There are shapes and places that even the best pictures cannot give one the idea how are they constructed/built.
That was the major contributing factor to buy Su-27 Flanker B Trumpeter Scale 1:32 kit and since I have it I will need to build it. Cool
I am a total newbie and I would like to ask very basic questions hoping for answers.
Thank you.
AJ
Tags: Su-27 , sukhoi
    January 2015
Posted by arb65912 on Saturday, May 21, 2022 7:01 PM
Here is one of the few mistates I already made.
I sanded off the little round pivot point from bot elevators, thinking that they are left overs from the sprue.
Drilled out and put the woodemn one, hope it will do the trick. Big Smile
Posted by Tojo72 on Saturday, May 21, 2022 7:02 PM
No pictures showing !!
    January 2015
Posted by arb65912 on Saturday, May 21, 2022 8:07 PM
I know, I can not upload picture from PC, it has to be link to a website.
Correct?
Posted by gregbale on Saturday, May 21, 2022 8:17 PM
arb65912
Correct?
Correct. Photos have to be on some version of a hosting site, then paste the links into your post here.
BTW...you're not the first to lop off bits of a part thinking they're sprue or tabs. We've all been there! Embarrassed
Greg
George Lewis:
    January 2015
Posted by arb65912 on Saturday, May 21, 2022 8:23 PM
gregbale
arb65912
Correct?
Thanks Greg!!!
Understood, now I have to tink of some fast free hosting site, any ideas?
I want to share pictures as this is absolutely necessary.
    February 2017
Posted by Tubosteve on Saturday, May 21, 2022 8:31 PM
Personnaly, I use   https://imgbb.com/
It's free to sign up and pretty siimple to upoad and share pics...........must be pretty simple as I use it Stick out tongue
Stay safe........Steve
Currently on the bench: On the bench: Airfix 1:24 Spitfire Mk IXc (17001) as Silver Spitfire G-IRTY, Revell 1:48 Bristol Beaufighter TF.X (03943)
Finished 2024: Tamiya 1:24 Ford Mustang GT4 (24354)
    January 2015
Posted by arb65912 on Saturday, May 21, 2022 8:37 PM
Tubosteve
Thanks, I will give it a try shortly.
For test these are from my Dropbox.
https://www.dropbox.com/s/s8cofectwf9lkdh/TEMP1.jpg?dl=0
https://www.dropbox.com/s/jvfq5u5c5w4cdl8/TEMP2.jpg?dl=0
    January 2015
Posted by arb65912 on Saturday, May 21, 2022 9:07 PM
Another try.
I like it a lot!!!
Now I am all set for sharing images. ;-)
    January 2015
Posted by arb65912 on Saturday, May 21, 2022 10:12 PM
Another try. I think this one will be the best.
Will try tomorrow, very late for me.
Posted by jeaton01 on Saturday, May 21, 2022 11:59 PM
I built two of those last year, I replaced those nubs with music wire that fit well in to the stabs and filled the area in the tail with epoxy which I then drilled out to fit the pins.  Trumpeter's engineering there is way understrength.  Make sure to install the little fairings that fit on top of the stabilators after you install the stabilators, if you glue them on first it is difficult to install the stabs.
John
    January 2015
Posted by arb65912 on Sunday, May 22, 2022 9:01 AM
Hi John,
Nice idea with the music wires.
Do you mean fairings that attach into the little holes on the top of stabilators?
Posted by jeaton01 on Sunday, May 22, 2022 9:12 AM
Yes.
John
    January 2015
Posted by arb65912 on Sunday, May 22, 2022 9:39 AM
jeaton01
Yes.
Hi John again. :-)
I just looked at your SU-27s. Wow, they are a measterpiece. I am not a scale modeler but if I wanted to build and finish like that, it would take me years of trial and error. Awesome work!!!!
You know I am building SU-27 for flight simulator called X-Plane so this build is kind of additional thing. I have to admit that it is very addictive, I mean making the scale model. I find it really relaxing and making mistakes is OK, it is a learning process.
Some mistakes are infixable, like my broken canopy, I tried to "open it up" and I broke it into 2 pieces and morecracks. I glued it back together and will sand and polish but the cracks will never go away. I have tried to find a new one but no luck.
Talking about SU-27 Stabilators, how did you glue them? I know there needs to be a gap around them as they move in real life. I assume that your piano wire was relatively long if it was the only piece holding them in place.
    January 2015
Posted by arb65912 on Sunday, May 22, 2022 9:45 AM
This is how bad my hand brush attempt was using Vallejo Air Paint.
Now, I know, they are really designed for airbrushing.
Main mistake was that I was still brushing while the paint already started drying, lesson learned
    August 2021
Posted by lurch on Monday, May 23, 2022 9:14 AM
As long as you learn from your mistakes then they are not bad ones. We all have made them at some point or another. Like you said we are always learning new techniques.For someone new to this you are doing pretty good.
    January 2015
Posted by arb65912 on Monday, May 23, 2022 11:02 AM
lurch
Yes, makes sense and thank you! Big Smile
Posted by jeaton01 on Monday, May 23, 2022 2:43 PM
Yes, the piano wire was as long as I could make it as it was the only support.  I filled the inside of the stabs and the aft fuselage attach areas with epoxy and then drilled them out to a close fit.  Super glue was used to glue the pins into the stabs and then just white glue into the aft fuselage.  That way if something bumps the stabs it is an easy fix.
Thank you for your nice words.  To really enjoy the hobby an airbrush is a great tool, but some people are good enough with a brush to get very nice results.  I'm not one of those people.
John
    January 2015
Posted by arb65912 on Monday, May 23, 2022 5:42 PM
jeaton01
I think, I understand, John.
If this is the design of gluing in the stabilators, than it is a quite poor design. The original taps were small anyway and having them supporting all these big control surfaces in place is not a very proper design wise.
I might just do what you did, the trick is to feel that are in fuselage, will look into it later on.
I am thinking about airbrushing the vertical stabs with rudders as well as elevators and gluing them at the end. I am sure not very popular idea, what do you think?
I love airbrushing, I can not imagine brushing all these big surfaces by hand...
Enjoy everything!!!
Cheers, AJ
Posted by jeaton01 on Monday, May 23, 2022 6:53 PM
If the fit were better gluing those surfases on last would be a good idea, but you will likely find as I did that getting good alignment and fit with the vertical fins will make that difficult.  Do lots of test fitting in that area.
John
    January 2015
Posted by arb65912 on Monday, May 23, 2022 7:44 PM
jeaton01
Yes, good  thinking, John. Thanks!
I will make final decision when I have fuselage bottom and top glued together.
I am also tempted by very "crazy" or at least not very common idea. You know how wings gets into the pins at the bottom of the wings so they will never come out after fuselage halves are joined?
I saw the guy struggling with wings dropping, actually one wing dropping and it took him a long time for it to get glued to the fuselage winthout hanging down.
These two pins that will not let the wings to slide out also do not let them to get closer to the fuselage side to get the better fit for gluing area where wing root touches the fuselage side.
Crazy idea is, what if I make wings to be able to slide in and then glue them after making the mentioned fit as good as possible?
    January 2015
Posted by arb65912 on Monday, May 23, 2022 8:57 PM
I finnaly tried Stynylrez Acrylic Primer White.
I added some Vallejo Airbrush Flow Improver as nozzle was getting dried and it went nice. I think that is what the primer should be after it cures. Surface is hard, you can sand through and there is no peeling or edges, smooth transition. Love it.
Posted by jeaton01 on Monday, May 23, 2022 10:10 PM
I don't remember any issues with the wing fit on the two I built, but it could be I just don't remember.
John
    January 2015
Posted by arb65912 on Tuesday, May 24, 2022 6:09 AM
jeaton01
Let's see later on. I need to really think it over. I will post here.
