Revell 1/48 F4U-4 Corsair Work in Progress
    January 2021
Posted by Teenage Modeler on Thursday, June 30, 2022 4:39 PM
Hello all. For the past 2 weeks, I've been working on my F4U since I wanted to finish it, after sitting on the model stash for 2 ish years. Anyway, I'm making great progress right now. I've finshed the cockpit, and I'm working on the landing gears, propeller, armament, and the tailwheel and the arrestor hook.
Here is my landing gear. I flattened the bottom of the tires to look as if the plane had weight.
I also finished my arrestor hook, with black and white stripes. I used XF-1and XF-2 Tamiya.
I painted the wheel wells with Tamiya XF-4 Yellow Green. I sealed it with Tamiya Semi-Gloss Clear, which I then weatherd with Tamiya's Panel Line Accent Black. I used it as a filter, so that the wheel wells look dirty, because the tires are always dirty. I only used Dark panel liner since that was one of my only weathering products. It turned out pretty good.
Moving on to the armament. I used reference photos to try and be accurate with the rockets. The instructions say to paint the end of the rockets as black, but photos say otherwise.
1/32 Vought F4U-1D Corsair®
So I decided to paint the ends with Vallejo Olive Brown, and white. I had to make 8 of those. I also painted the bombs the same Olive Brown, and the ends of those with Tamiya XF-3 Flat Yellow. The propeller, I painted with silver.
Here's what you're all waiting for. The cockpit. This was the most detailed one I made, since it's my 2nd one. I used Tamiya's XF-4 Yellow Green, and added a lot of Dark Green to make it more accurate. The reason is that cockpits are usually greener in color, meanwhile wheel wells are yellowish in color.
I painted the Instrument panel and the side (don't know the name) panels Flat Black. The buttons I used white, and  painted red over the white to make it visible. The dials of the instrument panel is drybrushed with white, instead of using the decals.
The Pilot, I used a variety of paints. I used a mix of Vallejo buff, a tad bit of olive brown to create the pilot's suit. I used dark flesh for the face, then gave it a wash of olive brown to darken it. I also used the same wash for the wrinkles of the pilot's suit to make shadows, and made some highlights as well. The boots I painted with flat black, and that is one of the biggest feet I've seen. Maybe a size 13?
Lastly, the propeller.
I painted the tips with Flat Yellow, and the black is a flat black, with a gloss look to it. I definitely sprayed too thick. Even after a day, the paint left fingerprints on it. I tried to wetsand the paint to level it out, and it worked a little. I applied the decals, and painted the spinner white. It definitely looks good.
Well, I'm gonna work on some other parts of the model. I will have to seal everything with Semi Gloss and add some panel liner to it. Then, I could start to glue the fuselage and prime and paint it. But, this is all for today. Hope you enjoy reading my progress Yes
Made you Look
fox
    January 2007
Posted by fox on Thursday, June 30, 2022 8:35 PM
Looking good TM!
Jim Captain
Stay Safe.
 Main WIP:
    January 2021
Posted by Teenage Modeler on Thursday, June 30, 2022 10:58 PM
fox
Looking good TM!
Jim Captain
Stay Safe.
Thank you :)
Made you Look
    October 2019
Posted by Tanker-Builder on Friday, July 1, 2022 9:07 AM
Hi!
       Yeah, his feet are big. I met "Pappy"Boyington before and he isn't or wasn't as large a man as I. I am under 200 lbs. and stand 5'6" in my stocking feet. Plus I only wear a size Eight and a Half shoe. It was tight for me in my restored B-25 to get in the cockpit at that!  And the seat was tight to each side of my hips without a parachute on to raise my heighth. P.S. "Pappy" passed didn't he?
    January 2021
Posted by Teenage Modeler on Friday, July 1, 2022 9:17 AM
Tanker-Builder
Hi!
Oh say, you have a restored B25? That's really cool. I never even seen one in person, boy it must look cool. Yeah, I'm around the same height as you, and I wear a size 10.
Made you Look
    September 2006
Posted by the Baron on Friday, July 1, 2022 11:07 AM
Tanker-Builder
...P.S. "Pappy" passed didn't he?
Yep, in 1988.
    September 2006
Posted by the Baron on Friday, July 1, 2022 11:09 AM
Nice progress on this classic kit, TM!
A tip for the pilot's goggles-paint them brown, rather than silver.  They'll look like tinted glass then.
    September 2012
Posted by GMorrison on Friday, July 1, 2022 2:09 PM
Teenage Modeler
You are doing nice work.
A word about paint. Acrylics dry from the outside, in. They quickly skin over, but remain soft for quite a while.
Spirit based paints dry from the inside, out. They remain sticky for quite a while until the spirits all gas off, and then they harden.
In either case, there is a simple solution. Wait a week between coats. Yep, that's what I said- a week. Others agree.
Have another model or two to work on, if you have a lot of free time. Otherwise, get your other chores done.
Cordially,
Bill
    May 2009
Posted by Pawel on Friday, July 1, 2022 5:35 PM
Hello!
Your build is lookin' good - judging from the photos you are having your fun!
I thought maybe you would like to try painting the tires dark gray instead of black - I think that would help them look even better. If you look at any real tire it's never or almost never black.
Good luck with your build and have a nice day
Paweł
www.vietnam.net.pl
    January 2021
Posted by Teenage Modeler on Saturday, July 2, 2022 7:48 AM
Pawel
Hello!
Paweł
Yeah, I thought of that, too. I used Tamiya's Grey Panel Liner and washed the black of the tires to tone down the black color. Now it looks dusty and a washed down color of black.
Also, thanks for the tip Yes
Made you Look
    January 2021
Posted by Teenage Modeler on Saturday, July 2, 2022 7:55 AM
the Baron
Hey man thanks for the advice, I was just glueing the canopy in then I saw your comment. Good thing I glued the canopy temporarily.
Made you Look
