Commander Fuchida's Aircraft at Pearl Harbor Markings?
    December 2010
Posted by Tom Beccone on Friday, September 23, 2022 4:58 PM
I have seen at least three different illustrations of the markings of Fuchida's B5N Kate as it appeared in the attack on Pearl Harbor on Dec. 7, 1941.
The first comes from the old Profile publicats which shoes his plane in bare metal on the windgs and fuselage. The horizontal and vertical stablizer are marked in red and yellow stripes which span the full chord of the stablizers. A small aircraft number appears in the top stripe on the tip of the vertical stab.
Illustration number two comes from Donald W Thorpe's book "Japanese Navel Air Force Camouflage and Markings World War II. It depicts the same striping on the stablizers as the illustration in Profile publications, however the wings and fuselage are now a solid green with the bottom of the plane in light grey. This book was published in 1977 and the author makes the point that this illustration was executed under the direction of Mitsuo Fuchida himself and so I am inclined to mark my plane this way however....
More recent illustrations on boxtop art from various manufacturers indicate a third scheme that shows the horizontal stabilzers as solid red while the vertical stablizer is red with three yellow stripes, the bottom two of which do NOT cover the full chord of the stabilizers while the top yellow stripe does. The aircraft number here is larger, in yellow, and  fills in the area between the top and second stripe down.
Is there anybody out there who can tell me which is the most accurate illustration of these three? I would like to get this right... the model I have is an old Nichimo version of the plane. It has been in my stash for years and I am soon ready to begin work on her. Tom Beccone, age 73, Exton PA
    September 2005
Posted by richs26 on Friday, September 23, 2022 8:00 PM
Here is an Aviation of Japan article with the Hasegawa depictions:
http://www.aviationofjapan.com/search?q=fuchida
Anbd the Hasegawa instructions:
https://www.scalemates.com/products/img/3/6/0/114360-28-instructions.pdf
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    July 2004
Posted by stikpusher on Friday, September 23, 2022 11:14 PM
A couple of photos exist of the aircraft at the time of the Indian Ocean raids in early April 1942. As you can see the green was quite well worn and flaking off by then, but the tail markings are well seen.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    August 2019
Posted by HooYah Deep Sea on Saturday, September 24, 2022 12:00 PM
Unfortunately, the best source was the late, David Aiken. But there are probably several documents of his floating around that give the info you are searching for. I will dig thorough my stuff to see what I can find.
"Why do I do this? Because the money's good, the scenery changes and they let me use explosives, okay?"
    December 2010
Posted by Tom Beccone on Wednesday, September 28, 2022 1:14 PM
Thannk you so much. Anything you can find would really help.
    December 2010
Posted by Tom Beccone on Wednesday, September 28, 2022 1:18 PM
Wow. Thank you so much. As a former US History teacher I really appreciate this kind of evidence and research on your part. Thank you very much.I did not know these photos existed. This would have been four months after the raid at Pearl. I wonder if the plane looked that distressed in Dec. of 41? Thoughts?
    December 2010
Posted by Tom Beccone on Wednesday, September 28, 2022 1:19 PM
Thanks so much for your reply and the articles and items you passed along. I really appreciate your help with this project.
    August 2019
Posted by HooYah Deep Sea on Wednesday, September 28, 2022 2:15 PM
No problem, and next time you drive through Paoli, say hi for me. I Mis-spent a chunk of my youth in that area. I even wrote a kids book (fiction, ages 8-12) set there.
As for Fuchida's B5N, most of what I can find indicates the red tail and upper surfaces of the stabilizers, not to include the actual fuselage, with light gray below.
I would have expected the aircraft to appear fairly pristine upon departure from Japanese waters, and only minimal distress from the crossing. It was a 'lead' aircraft, after all.
