Hobby Boss 1/48 A-7E Corsair II Sidewinders - Work in progress
    September 2019
Posted by Nikola on Thursday, June 22, 2023 10:12 AM
Hi gents,
Parallel to my favourite subjects and scale, 1/32 WWII, I like to have a 1/48 jet project on the side in case I need a slight change of scenery from time to time. :)
Hence my work on Hobby Boss' Corsair II.
For the extras I am using Aires resin cockpit set with PE included.
I am doing the "Sidewinders" livery.
So far no trouble. The fit is very nice, especially the wings (dry fit tested).
Best,
Nikola
Box art and refs:
And some work pics:
            www.shelfforce.com
    July 2004
Posted by stikpusher on Thursday, June 22, 2023 10:23 AM
Nice start. Just a suggestion, but don't use the AIM-9L Sidewinders if you're doing the 1975 markings. That version of the missile hadn't been developed yet. The Navy was still using the AIM-9D/G/H versions.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2019
Posted by Nikola on Thursday, June 22, 2023 11:59 AM
stikpusher
Thanks Stikpusher! Appreciated.
I know very little on the subject so any tip is valuable.
Best,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Sunday, July 9, 2023 1:24 PM
Well, enter putty, from head to toe, top and bottom. It was a must, at least for me. I think it's of my own doing because of the resin cockpit fitting and adjustment.
And some minor play with exhaust weathering just to give it a bit of life.
Best,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Monday, July 10, 2023 5:30 AM
A bit of filling and levelling with Mr. Finishing Surfacer 1500:
            www.shelfforce.com
    September 2019
Posted by Nikola on Monday, July 10, 2023 5:40 AM
Now, here is a problem which is a bit more challenging - The inner side of the intake "ring" is much narrower than the inside of the intake tube.
I think that I can't sand it because the ring is a hollow shape so I might lose all the material of the inside part of the ring, and also make the intake much narrower.
The only feasible solution which I can think of for now is to fill in the step and make a gradual taper towards the back of the tube.
Don't know. Any suggestions?
Best,
Nikola
            www.shelfforce.com
Posted by oortiz10 on Monday, July 10, 2023 12:22 PM
Nikola, when I built HB's -A version, I had the same problem with the intake. I decided that trying to fix it might cause more problems than it would solve. I left mine as it is. Sorry that I don't have a solution to offer. Still, I'd like to build another HB A-7, so I'm curious to see if you come up with a solution that I might be able to use in the future.
Good luck!
-O
-It's Omar, but they call me "O".
    September 2019
Posted by Nikola on Monday, July 10, 2023 1:32 PM
oortiz10
Good luck!
-O
Hi Oortiz,
Thanks for the reply.
Actually, I am kind of with you on that one. Especially because this is my, so to say, side build.
I'll see if I have the patience.
Best,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Monday, July 10, 2023 2:44 PM
oortiz10
Good luck!
-O
The solution might just be something like this :)
            www.shelfforce.com
    September 2019
Posted by Nikola on Tuesday, July 11, 2023 8:22 AM
Does anyone know the colour of the FLIR "eye"?
            www.shelfforce.com
Posted by oortiz10 on Tuesday, July 11, 2023 10:59 AM
Hey Nikola, be sure to take a look at the rudder's outline. It was wrong on the -A boxing.
Hobby Boss extended the rudder to the bottom of the fin cap, like this:
But the real -A has the rudder line stop below the fin cap, like this:
It might not matter for you because the -E has the fairing towards the top of the tail.
As far as the "eye" goes, in the pictures I've seen, it looks like it's a dark tinted color. Although, it might be "clear" with a dark interior.
Here are a few pictures...
https://pbs.twimg.com/media/ESBGFt2VAAIGtnl?format=jpg&name=900x900
https://nebula.wsimg.com/980b7c20dffef80bba3127ef054ca4fc?AccessKeyId=72D92AAD40295CE2D368&disposition=0&alloworigin=1
https://www.thedrive.com/the-war-zone/34405/the-a-7-corsair-iis-heads-up-display-was-a-revolution-in-air-combat
https://www.airliners.net/photo/USA-Navy/LTV-A-7E-Corsair-II/1257947/L
Cheers!
-O
    September 2019
Posted by Nikola on Saturday, July 15, 2023 7:13 AM
oortiz10
Thanks Oortiz! Much appreciated.
Best,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Saturday, July 15, 2023 7:15 AM
Pre-shading done:
            www.shelfforce.com
    July 2004
Posted by stikpusher on Saturday, July 15, 2023 5:05 PM
I know that pre shading is a great weathering technique... but man does it make a build look ugly at that point! Even if it is only temporary... Surprise
       - Plankton
LSM
    September 2019
Posted by Nikola on Thursday, July 20, 2023 7:36 AM
Well, I managed to f' it up. Switched the FS numbers and instead of Light Gull Grey I used Ghost Grey for the low vis scheme. I saw that something was off but didn't do anything about it during painting. After I checked it was too late.
Three options available - mask and paint again losing all subtle pre-shading, mask and correct with a filter or leave as it is...
            www.shelfforce.com
    July 2004
Posted by stikpusher on Thursday, July 20, 2023 2:28 PM
Personally I'd say mask off the white and do a coat of Light Gull Gray. You could even use the Ghost Gray as something of a pre shade...
       - Plankton
LSM
    January 2020
Posted by wpwar11 on Thursday, July 20, 2023 2:59 PM
I think Stik has the right idea.  You can use it to your advantage.  Maybe spray a white marble coat then spray a thinned top coat for subtle shading.
Posted by oortiz10 on Thursday, July 20, 2023 4:55 PM
I agree with the previous two suggestions. If it was me, I'd mask the white and marble white and various shades of other grays over the Ghost Gray before covering with LGG.
    September 2019
Posted by Nikola on Friday, July 21, 2023 11:09 AM
Here it is corrected.
I decided that the easiest thing to do is  just go over it with the correct colour to make sure I got it right this time and then later modulate with post-shading/tinting and filters.
This way I avoid having too many coats and ruining the surface detail if I don't get it correct right away which would most probably have happened.
Best,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Friday, July 21, 2023 11:12 AM
stikpusher
wpwar11
oortiz10
Well, didn't think of that at all. Good idea guys. Read this after I painted. Bang Head
Will have it in mind for the next f' up though. :)
Best,
Nikola
            www.shelfforce.com
Posted by oortiz10 on Friday, July 21, 2023 11:28 AM
Nikola
Here it is corrected...
Nice save!
    September 2019
Posted by Nikola on Friday, August 18, 2023 1:20 PM
After tedious masking here are the electronics bays painted in base colours. Some cleanup and corrections are required prior to washes, dry brushing and details.
            www.shelfforce.com
    September 2019
Posted by Nikola on Friday, August 18, 2023 1:21 PM
Now, this is a b%$ch! I assume that Aires just relabeled the parts to say for Hobby Boss while it is actually for Hase, Academy, Trumpy, whatever... The AM part is significantly shorter than the kit part so there is a big gap.
I need to think of the way to remedy this.
            www.shelfforce.com
    September 2019
Posted by Nikola on Friday, August 18, 2023 1:22 PM
I also started making the intake cover. Luckily, there are two intake "mouths" provided so I used the other one as a template:
            www.shelfforce.com
    September 2019
Posted by Nikola on Friday, August 18, 2023 1:23 PM
Also, again after tedious masking, the cockpit base colours and a gloss coat are done:
            www.shelfforce.com
    July 2004
Posted by stikpusher on Friday, August 18, 2023 4:27 PM
The intake cover and cockpit look good Nikola! Keep it up!
       - Plankton
LSM
    September 2019
Posted by Nikola on Wednesday, September 27, 2023 3:34 AM
The Corsair slowly advances... My phone sincerely apologizes for the photo quality. :)
            www.shelfforce.com
fox
    January 2007
Posted by fox on Thursday, September 28, 2023 11:15 AM
Great work on the equipment and pit details! Toast Toast Toast
Stay safe.
Jim Captain
 Main WIP:
    June 2014
Posted by BrandonK on Thursday, September 28, 2023 11:58 AM
Very nice work. That looks really good, even if the phone is to blame. Excellent.
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    July 2004
Posted by stikpusher on Thursday, September 28, 2023 9:49 PM
Very nice work on the cockpit! Keep it up!!!
       - Plankton
LSM
