F-111 kits
    December 2023
F-111 kits
Posted by Gunnie on Monday, December 18, 2023 7:00 PM
Folks,  another project that's on my list is to do a couple of dioramas of aircraft that I worked on during the early years of my service.
The aircraft in question is the venerable GD F-111C & the RF-111C.
I had two postings to No6 Sqn RAAF & a brief posting, straight out of trade training, to the intermediate level maintenance unit 482Sqn. I was a Gunnie, Armament Technician, in the RAAF and in the early years of my 40yrs service,  spent time working on the grand ol' Pig.
During my first postings I was involved in all armament aspects on the Pig, including HE & Inert/Prac bombs, Guided ordnance, crew module EO & gun systems. Our C models were fitted with the Vulcan M61A1 20mm cannon inthe early years & I conducted operational level & intermediate level maintenance tasks such as ball/HE 20mm load/download, gun system fit/removal,  cold & hot gun bore sightings.
I prepped/loaded/downloaded Mk82 500lb LD/HD, Mk84 2000lb, GBU 10/12/15 LGB/TV guided bombs. Also AGM-84 harpoon, AGM-142 prep/load/download. The usual Pivot pylons fit/removes, SUU-20A/A units for BDU-33CB 25lb Prac bombs & BRU-3A/A 6xMk82 bomb racks.
We also did the fit/removal of MXU-4A Cargo pods & 600gal supersonic fuel tanks. In the early years the left side of the weapons bay was normally empty, unless we installed an internal fuel tank or cargo pannier. I also had the privilege of prepping/loading the Australian designed/built Karinga CBU.
On my return to 6Sqn in 2003 the Pigs were no longer fitted with the gun system.  All had been replaced with the Pavetack targeting pod. This led to more frequent programs using LGB's.
As such there is a significant amount of items to factor in to my dioramas. I want to do a classic C model in Sth East Asia tri-colour camo, specifically A8--131, the aircraft that I had my posting out ride in. I would also like to do a 2nd dio of one of the recce birds that were solely operated by 6Sqn. A8-126 was always a favoured bird as it seemingly had a high serviceability state.
I dare say I'll have to also consider doing a third dio of a later posting Pig done in the low viz grey paint scheme & as a Pavetack bird.
I have the old Minicraft/Academy 1/48 kit which I plan on using the aftermarket long span wing kit on. This will be my classic C model dio.
My question to the learned is opinions on the Hobby Boss kit & it's accuracy as to classic C model or later AUP update grey C models.
Thanks in advance.
    February 2022
Posted by BattleTweety on Tuesday, December 19, 2023 12:49 PM
Hi Gunnie,
I built the Hobbyboss 148 F-111C Australian version back in mid-2020, these were my thoughts at the time with regards to accuracy as a C model:
There are a couple of things the RAAF F-111C doesn't have that this model came with:
- Front circular hatch cover on nose
- trailing edge ECM rods on the rear stabilizers
- Cockpit control panel options don't have the RAAF version
- the ordanance is designed for the US, not indicative of what the RAAF carried.
I also checked the wingspan as the F-111A had a shorter wingspan than the RAAF version, but thankfully it seems to be correct.
The RAAF decals the kit comes with also need to be given a caution, I don't believe the RAAF version uses light yellow panel markings and the squadron markings should be a blue lightning symbol not black.
Its still a nice kit though, things above easily rectifiable, and an enjoyable build of my favourite RAAF aircraft in my favourite colour scheme.
My build pictures below for reference..
hope this helps
cheers
BT
On the neverending quest for the perfectly built model kit.
Posted by keavdog on Tuesday, December 19, 2023 1:27 PM
Thanks,
John
    April 2020
Posted by Eaglecash867 on Tuesday, December 19, 2023 6:00 PM
Hi Gunnie,
I can't really say much about the accuracy of the Hobby Boss kit as a whole, but if you were planning on having the weapons bay open, the detail in the Hobby Boss weapons bay is superb.  I ended up grafting one into the Minicraft/Academy 1/48 FB-111A build I have been nibbling on here and there for a while.  It adds a lot to that old FB-111A.  I'm sure you probably know about all of the OzMods stuff you can get for Pigs, and maybe also check out DMolds for resin intakes.  There's probably going to be a bit of an issue getting DMolds stuff, since the guy who makes the stuff is based in St. Petersburg, Russia.
Here's that Hobby Boss weapons bay grafted into the old Minicraft.
"You can have my illegal fireworks when you pry them from my cold, dead fingers...which are...over there somewhere."
