Classic Airframes Resin 1/48 Fw190 V1
Posted by jeaton01 on Tuesday, January 23, 2024 10:07 PM
The first Fw 190.
It was a welcome surprise to see this one appear and I did not wait to get one as resin kits usually have short production runs. MPM made a 1/72 kit in 1995 that used the same box art.
A well cast resin kit with white metal gear.
The V-1 resin parts superimposed over and next to Tamiya F-8 parts. The V-1 and other early Fw 190's had BMW 139 engines that did not develop into a successful design. The 139 was the same diameter but shorter and lighter than the BMW 801.  When the change was made to the BMW 801 the cockpit was moved back and the forward fuselage was lengthened. The forward fuselage was slightly lengthened again on the A-4 and that was the last fuselage length change until the Jumo and Daimler powered versions. Because the 801 was heavier, and because of other weight increasing changes planned, the wing was re-designed, with more span and less taper to bring the stall speed and maneuverability back to the level of the prototype. The BMW 139 had serious heating issues and with the original engine and forward cockpit position temperatures reached 50 degrees centigrade at the rudder pedals.
The canopy had a longer clear section and there was a different headrest.
All the parts separated from the pour blocks and washed up to get any mold release removed. I also reworked an area of the right fuselage half that had a sort of bulge below the windscreen, not sure how that came about but it's all good now. Looks like fit of the major parts is pretty good.
I made some decals for the instrument panels on this one, using a Yahoo panel but resized. There is some dithering visible in the photos but if you look up close at Eduard and other products there almost always is. The smaller panel is only about 1/2 inch wide so since you won't be able to see it tucked up under the glareshield it will be fine. Way better than my shaky hands can paint!
There was no provision for a prop shaft and I don't like props that are not removable so I installed a music wire shaft in the prop hub and a brass bearing in the fuselage, which has been glued together.  The cockpit can be fit from the bottom and it has also been verified that the wing to fuselage fit is good to go, which involved a lot of test fit and trimming on the cockpit tub.
There was some chasing of my tail because I lost the front fairing for the spinner. Of course I looked everywhere, cleaned everything up, all that. Finally gave up and made a new one out of Epoxysculpt. As I was finishing it up, I dropped it, still haven't found it. But as I started looking I found the original part out in the middle of the floor. How I didn't step on it over the last day I have no idea. Somebody up there is seeing if I am related to Job, perhaps. Since most of the trimming and fitting of parts is done assembly should go forth now. Until the Fates strike again.
John
GAF
    June 2012
Posted by GAF on Wednesday, January 24, 2024 1:17 PM
Very nice build, John!  I sympathise with losing the hub.  Seems like they can disappear into that black hole that lives under my desk.  Sad
Gary
Posted by jeaton01 on Sunday, January 28, 2024 9:01 PM
Got all red dog on this one yesterday, every time I thought I should wait a bit more for what I just painted to dry the devil on my shoulder said go for it. Other than having trouble with getting the glue to hold on the right stabilizer and having to repaint the swastika on the left side because some black crept under the masking, things worked out well. Hataka was used for the 65, Model Master for the 70/71, and Tamiya for all the markings. Masks cut on my Cameo for the markings after drawing them up in Autocad. I just taped off the splinter pattern using resized drawings from the instructions to lay them out. A few brain twisters involved in that but I think I got it right. Let me know!
The fit on this kit is very good, although with resin there is always a bit here and there to puzzle out how things fit and this one was no exception. Very little filler, mainly just on the bottom on the front and rear wing joins. Also the fuselage seams needed a little attention, but very little. The wing root to fuselage fit was too tight but a little careful sanding on both sides and attention to fitting the cockpit tub took care of that.
John
    May 2022
Posted by Eugene Rowe on Monday, January 29, 2024 5:54 AM
Came out great!You can see how the initial spinner design would block airflow to the cylinders!
GAF
    June 2012
Posted by GAF on Monday, January 29, 2024 9:42 AM
That turned out great, John!  Judging by photos, you got the lettering spot-on!
Gary
fox
    January 2007
Posted by fox on Monday, January 29, 2024 4:05 PM
Very nice build John! Great pics too!
Stay safe.
Jim Captain
 Main WIP:
Posted by jeaton01 on Tuesday, January 30, 2024 12:17 PM
Thanks, everyone.  The comments are much appreciated.
John
