Tamiya F-15E Strike Eagle 1/32 Complete
    January 2015
Posted by Aggieman on Sunday, April 7, 2024 4:20 PM
This is my second build for the year, and it's a monster.
I had my eyes on this kit for years before finally pulling the trigger on it about a year ago. I had built an older Monogram release in 72nd scale when I was a kid, and more recently a Revell release in 48th scale, which still adorns one of my display shelves.  This kit puts both of those to shame just in its mere presence - it is big and it looks fantastic.
I had experience with another Tamiya 32nd scale jet, the F-4B Phantom II, that I built nearly 20 years ago.  On that build, I struggled with the seams in the air intakes before finally stumbling across resin FOD covers for that bird.  Problem solved with a bit of red paint and some CA.  I researched this Eagle and found that the intake seam was a problem on this one as well, so I had FOD covers on hand for it before it ever found its way to my bench.  I also added after-market seats that came with molded on seat belts.  The only other after-market items I used for the Eagle were left-over from the Phantom build - REMOVE BEFORE FLIGHT tags.  The Eagle kit actually comes with a paper sheet of these tags, and I used a few of them, but wanted to use what I had remaining from that old Eduard PE sheet since I don't envision building another 32nd scale modern jet fighter.
I used AK Interactive F-15 Dark Grey (MOD Eagle) for nearly all of the external surfaces.  The metallic areas are AK Interactive XTreme Metals Matte Aluminum and Steel, and Jet Exhaust.  The nose cone often fades different from the remainder of the aircraft, so I left that with only the Grey Stynylrez primer to offset from the look of the F-15 Dark Grey (MOD Eagle).  Tamiya lacquers (white, yellow, red, flat black), Tamiya acrylics (sky grey, semi-gloss black) and Model Master acrylics (clear red, clear green) round things out.
This was not a trouble-free build as typical of Tamiya, but that was more on me than the kit.  The canopy featured what I have come to find fairly consistent with Tamiya kits a seam line running right over the top of the part.  I was able to sand it away with no problem, sand it with progressively finer sanding pads, and then finally go at it with polishing compounds.  That seam did disappear.  I masked everything and put the wind screen and canopy in place (wind screen glued, the canopy on its rails fit pretty snug without any adhesive).  It was only when I was done with all painting and able to remove the masking that I found that liquid glue had found its way under the masking on both parts.  Heck of a mar job on the parts that I would be unable to conceal.  I used the same techniques as with the seam to progressively remove the marring, but ultimately there is a "shadow" of that marring that remains.
I also noticed just yesterday that I mounted the ordinance incorrectly one one of the pylons.  The Sidewinders should be on the inbound side, but I managed to not take that into account on one.  I contemplated fixing the problem, but opted against doing so for fear of ruining those parts and having to obtain new copies of them.
Next up - Modelsvit's F-82G Twin Mustang.
    July 2008
Posted by Est.1961 on Sunday, April 7, 2024 4:43 PM
Wow that's lovely, like the tags and how they look on it have never used them myself they do look good. I'm actually building a 1/32 P51 Mustang from Revell right now first ever at that scale taking my time and enjoying it.
Joe
Posted by keavdog on Sunday, April 7, 2024 5:13 PM
Turned out great!  Pit detail is amazing.  She's loaded for bear.
Thanks,
John
fox
    January 2007
Posted by fox on Sunday, April 7, 2024 9:07 PM
Amazing work! I totally agree with the great work in the pit! Could be a pic of the real thing. You wonder how she gets off the ground with that heavy load.
Stay safe.
Jim Captain
 Main WIP:
GAF
    June 2012
Posted by GAF on Sunday, April 7, 2024 9:09 PM
That's a mighty fine looking Eagle!  Well done!
Gary
    June 2018
Posted by DRUMS01 on Sunday, April 7, 2024 10:51 PM
Nice build Aggieman! Your persistence and great modeling skills made this shine.
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
    March 2022
Posted by missileman2000 on Monday, April 8, 2024 7:50 AM
I plan to do a Streak Eagle from an -a or -c kit.  Probably  in 1:48 scale because of cost.
When I worked at MDD they scrapped the plane after the flight and stuck in a scrap yard outside my office.  I have been interested in that ac ever since.
i
Posted by jeaton01 on Monday, April 8, 2024 11:10 PM
Looks great, Stephen.  It's a nice kit but as you say not completely trouble free.  I built three of them and by the time I was done I was really tired of fixing ejector pin marks on the inside of the burner cans.
John
    August 2021
Posted by lurch on Tuesday, April 9, 2024 5:32 AM
That looks fantastic to me. I don't know much about the Eagle but you did a great job on it. The remove before flight tags realy stand out perfectly. The cockpit work is remarkable .
    January 2024
Posted by Cory on Wednesday, April 17, 2024 5:06 AM
Wow, excellent job! And, that must be a monster. The 1/48 scale ones are pretty big themselves...aren't they? I can only imagine how big this one is.
    January 2015
Posted by Aggieman on Friday, April 19, 2024 10:55 AM
Thanks for everyone's kind words.
    April 2008
Posted by spiralcity on Saturday, May 11, 2024 2:48 PM
That looks great!
