- Member since
Posted by oortiz10
on Thursday, July 11, 2024 5:52 PM
SON OF A...!
More on that in a minute.
So, let me start by saying that all the great things people have said about the Tamiya Jug are true. I found myself grinning while putting these birds together. I've always been leary of inserts included in plastic kits, but I was delighted by how well the Tamiya parts went together. I had been waiting to get some resin seats to finish my cockpit, and while I did, I got the wings built up. They look worse in the photos than they really are. All in all, the assemblies went together beautifully.
![](https://i.imgur.com/KcGr9Ls.jpg)
While I was working on the wings, the barrels I bought arrived. A nice little surprise was that the barrels' set comes with a ring and bead sight. So, I built up gunsights after the wings.
![](https://i.imgur.com/7N3Q16R.jpg)
![](https://i.imgur.com/PINaQll.jpg)
![](https://i.imgur.com/Bw459IF.jpg)
I'll install them toward the end of the build in order to protect them when I mask the cockpit for painting. They're not perfect, but they'll look good enough from 3-feet.
I also noticed that one of the airframes I'm going to build is a later -D with the tail fillet installed. The Tamiya -D does not include the parts to add the fillet. It turns out that I built a couple of Hasegawa Jugs as gifts some time ago. I usually keep all the parts from a build that I don't use, and I kept the Hase parts for the fillet and pulled 'em out to use.
![](https://i.imgur.com/6dmBjmL.jpg)
With a little fiddling, the parts fit well enough to pass muster.
![](https://i.imgur.com/WbIRgLJ.jpg)
Finally, the seats I had been waiting for arrived. They're from a company called RESIN2detail and found them on...that auction site. They're beautifully printed and detailed. Unfortunately, they're not a direct drop-in replacement for the Tamiya parts.
The resin seats have the top cross-member printed as part of the piece...
![](https://i.imgur.com/C8BdpdD.jpg)
...whereas the Tamiya parts have the crossmember molded onto the armor plate.
![](https://i.imgur.com/NIDFiCv.jpg)
If I was going to use the resin seat, I'd either have to alter the resin seats or the kits' parts because the resin seat wouldn't sit well if I left the kit parts alone.
![](https://i.imgur.com/1DdKNss.jpg)
I went with the latter. I used some Tamiya Extra Thin to soften their joints, then carefully removed the headrests to avoid damaging them.
![](https://i.imgur.com/G3uYuHM.jpg)
Then using a hobby knife and some needle files, I carefully removed the kit detail.
![](https://i.imgur.com/Qk5wgIY.jpg)
After a repaint, things looked pretty good.
![](https://i.imgur.com/hurBUkz.jpg)
But I found that the seats still needed more attention in order to work. The resin seats didn't have any mounting supports, so I had to cut the "feet" off of the kits' parts...
![](https://i.imgur.com/uVU5Ety.jpg)
...and install them onto the bottom of the resin seats.
![](https://i.imgur.com/u1BKdl3.jpg)
After some tweaking, I was able to get the seats to work with the kit plastic.
![](https://i.imgur.com/8NCCHAy.jpg)
So, here's where the @#$%&! moment happened...
I was excited to finally get the cockpit completed so that I could close up the fuselage. I must've had target fixation and mad a very significant mistake. Can you see it?
![](https://i.imgur.com/pm8W6NU.jpg)
If it's not readily obvious to you, let me tell you what I did. I closed up the fuselages without installing the wing spar assemblies!
ARE YOU FREAKIN' KIDDING ME!?
Luckily I noticed while the joint's plastic was still soft. Using some more Extra Thin and a lot of curse words, I was able to melt and soften the joint enough to pry the fuselage halves apart...
![](https://i.imgur.com/qvlWDDj.jpg)
...install the spars, and close up the fuselages. Again.
![](https://i.imgur.com/iBTJdQb.jpg)
I have no idea if I will be able to save these builds. I noticed that when I rejoined the halves, the plastic was very soft and easily squeezed through the seam lines. I'm hoping that the extra soft plastic will harden up and help fill the seams. I'm sure it'll be a few days before things set up enough for me to check. I'll keep working on the subassemblies in hopes that the fuselages can be used and the builds can be saved. I'll let you know. Do me a favor and keep you fingers crossed. I can use all the good modeling juju I can get. In the meantime, I'll work on the Blackbirds.
Anyway, as usual, comments, questions and criticisms are welcome. Feel free to drop your two cents into the bucket on your way out.
Cheers! -O
-It's Omar, but they call me "O".
