First, welcome to the Forum
, glad to have you aboard. Not sure what paint you were using as a flatcoat, but sounds as though it was either thinned too much, or the AB was too far from the model, which can allow some of the atomized paint from the AB to dry before it hits the model. It leaves a whitish, gritty appearance on the model. Only way I have ever been able to remove it was with a light sanding with very fine micromesh pads & repainting. With the rigging & all on your model, that might be a bigger problem. If you were spraying over Future, there is a slight chance that the Future reacted to the flat coat & clouded. If thats the case, another coat of Future might, stress might, help.
RICK
At My Age, I've Seen It All, Done It All, But I Don't Remember It All...
