Golden Hawk's Sabre
Golden Hawk's Sabre
Posted by Neb L. Weffah on Tuesday, December 31, 2002 9:35 PM
Hi. I'm from Calgary and I want to build Hasegawa's 1/32 F-86 into a RCAF Golden Hawk's Canadair Sabre 6 aircraft. Any suggstions on the paint? I'm told they where covered in a special mix called 'Sheffield Luxor Pale Gold'. Anyone know of anything close to that? What have othe modellers used? I also need reference material for the exterior smoke piping systems and how it was connected to the smoke oil tanks in the gun bays. I think the bottom .50 cal. guns where taken out of each bay so the smoke oil tanks could be fitted but I'm not sure. Any photos of this area? More later and thanks....
Posted by upnorth on Thursday, January 2, 2003 12:32 PM
I saw a Golden Hawks Sabre at a competiton once, I think it was 1/48 scale.
The fellow who built it told me he used Humbrol enamels in a 2 to 1 ratio of gold to silver. It looked as close to the gold color of the Sabres as I've ever seen in models.
Hope that helps
Posted by Anonymous on Saturday, February 15, 2003 1:11 PM
This will probably date me, but back in 1967 I worked as a summer student working at an airfield outside Belleville, Ontario dismantling old F-86 Golden Hawks. There were definitely NO guns in those bays. For a flight demonstration aircraft, they would have added a lot of extra weight. Interestingly, the gunsight radar was still there (with accompanying black box in the cockpit), but the cartridge magazines and all related equipment was removed. (In fact, the gun mounts were still there, and we ruined some power bars and sockets getting those mounts off - they were really torqued on.). I do remember that the gold was not really brilliant (upnorth's solution sounds about right). At the time these were flying, the bare aluminum was kept pretty shiny, but, by the time we got to them it had that grayish patina of oxidized aluminum. Kind of a sad end to some pretty striking aircraft. As for oil lines, it was simply a pipe (about 3/4") which ran down the side of the fuselage and vented into the exhaust. I don't know how it was hooked to the oil tanks you speak of - they had been removed prior to our srapping the aircraft.
Posted by spacenut on Sunday, February 16, 2003 4:08 PM
Neb,
A while ago, I kitbashed the Hasegawa 1/48th scale F-86F-40 wing to an F-86F-30 fuselage. The wing had to be converted first. This gave me a Canadair Mk. 6 Sabre Jet, similar to the one flown by the Golden Hawks in the early 1960's. The paint scheme is a flat gold finish. Don't be suckered in by photos of models in shiny SnJ paint. Tamiya's Gold Leaf will work perfectly as it did on my model.
Leading Edge Models (based in Calgary) has a 1/32nd scale decal sheet that is what you need. I found the 1/48th scale sheet to be all-inclusive as a reference. Not only were there color photos of the jets, but some nice looks at the external smoke lines used on the Mk.6. Check out their website. I sent them photos of Golden Hawks Sabre recently and they were going to post on the site. Not sure if they've done it yet.
Regards,
Randy
    January 2003
Posted by Keyworth on Monday, February 17, 2003 6:02 PM
Randy, the Leading Edge website has your Sabre. Nice job!!
"There's no problem that can't be solved with a suitable application of high explosives"
    January 2014
Posted by Silver on Monday, April 28, 2014 5:37 PM
I just stepped out of my time machine from the year 2014.Wow!I would recommend that you use a base coat of Tamiya Gloss black w/the follow up of Tamiya Gold..Most Golden hawks were flat finish or semi gloss depending the year.Well,It's time to step back in because I am going to the year 1998.Take care.
Posted by rangerj on Monday, April 28, 2014 7:53 PM
IIR there were T-33s with that paint scheme as well? I like flashy paint schemes and Canada has some of the best. The Red Indian F104, the series of F101B;s "Hawk One", Alouete, Lynx, and Electric Jet, as well as the Golden Hawks are great examples. The Canadians also did some super "Tiger Meet" color schemes. I look forward to seeing your F-86 Golden Hawk, eh.
