is there rules in painting ??? What type is GUNZE?
Posted by Anonymous on Friday, April 11, 2003 1:55 AM
Iam an architect and a scale hobbyist. In building construction the rule in painting is never mix enamel with acrylic & vice versa.
In modelling i have encountered and used TAMIYA ACRYLICS, which is water soluble and easy to apply. Iam also familiar with TAMIYA ENAMELS which i used before using the ACRYLICS.
Last month, while looking for a CLEAR GLOSS PAINT, a hobby attendant gave me SANGYO GUNZE brand of paint. I used the TAMIYA ACRYLIC THINNER and it turned into a plasticky goo.
Addicts of Scale Modeling RULES!
buddha
Posted by rjkplasticmod on Friday, April 11, 2003 9:15 PM
Gunze is an acrylic paint but not all acrylics are compatible with all thinners. You don't often run into this problem with petroleum based paints as enamels can be thinned with lacquer thinner for example. If you use the thinner from the same manufacturer as the paint you will usually be OK. When mixing manufacturers as you did, you always want to test a sample first. The goo you describe is pretty typical of an acrylic mixed with an incompatible thinner. I don't use acrylics much but when I do I usually try distilled water or alcohol as a thinner. By the way, for a clear gloss you should try Future floor finish which is an acrylic but can be airbrushed unthinned and cleaned up with alcohol.
Rick
Posted by Anonymous on Saturday, April 12, 2003 10:15 AM
TO: Rick
Thanks for the tip.
Posted by naplak on Saturday, April 12, 2003 10:34 AM
Alcohol works okay with most all Acrylics (haven't found one it doesn't work with). But I try to always use the name brand thinner... just in case. For the cost of the model, and the time involved, the price of branded thinner does not seem to be much of an addition.
www.naplak.com/modeling ... a free site for modelers www.scalehobby.com/forum/index.php ... a nice Modeling Forum
Posted by BlackWolf3945 on Saturday, April 12, 2003 3:40 PM
I don't generally use acrylics myself, but a pal uses them almost exclusively. He's had very little trouble with using alcohol as a thinner for most any acrylic he's tried.
He did run into one snag recently. He thinned Model Master Acrylic Clear Flat with alcohol and it separated on the model. It went on okay, but when he came back to put another coat on, it had separated and looked as though it had cracked. (Didn't actually crack, that's just the way it looked.)
I used Gunze paints sometime back before I became BAE. (born-again enamel) I had nothing but trouble with 'em.
If you have doubts about any paint/thinner combination, try it out on a scrap model first.
Fade to Black...
Posted by jcarlberg on Saturday, April 12, 2003 9:55 PM
Like many makers, Gunze Sangyo has both acrylic and solvent based paint lines. The "acqueous" colors are distributed in the USA, but they also make the Mr. Color enamel line, which are solvent based. In my experience, Gunze acrylics are very touchy about thinners and clear coats, and I can only recommend using their thinners and clear coats with their paint, which is of very high quality.
Posted by Anonymous on Sunday, April 13, 2003 9:46 AM
to EVERYBODY,
Thanks to your wonderful inputs on GUNZE paints.
Buddha
