Having issues painting missiles
Posted by RonUSMC on Tuesday, April 22, 2003 9:57 AM
Those little stripes are a pain. I use Tamiya tape to tape off the edges, but if I use a brush the paint still gets under the tape.. then painting white over the color is a hassle.
What do you recommend? Striping tape?
http://finescalegallery.com Active Kits: 1/48 AM Avenger 1/35 Sd.Kfz 251 Ausf C
Posted by Ray Marotta on Tuesday, April 22, 2003 10:34 AM
You could seal the tape edges with some clear. Solid color decal material
is another possibility.
Posted by Anonymous on Tuesday, April 22, 2003 10:47 AM
I paint the base color and put tape on one of the sides of the stripe, brushing the stripe color away from the tape. I then add tape and paint the base color again until the part I don't want is invisible
Posted by Anonymous on Tuesday, April 22, 2003 11:25 AM
I got lucky once and used a left over decal. It was a wide fuselage band from a Typhoon (I think) and i cut it into strips to make bands for missiles. Depending on the band color (Missile) you could also use a left over tail flash etc. Just check your left overs. Just make sure you use an accurate measuring tool, I use a 6" machinists steel rule that goes down to 1/64" (.0156").
Posted by Wingman_kz on Tuesday, April 22, 2003 3:44 PM
I hope you don't mind me sticking my nose in here. I may be way off base but there was a tip in the Dec. 2002 issue of FSM from H. Scott Edwards on striping bombs for a B-52 he was building.
He used a small DC motor powered by a couple AAs and a piece of wood doweling. Drill a hole in the dowel to fit the shaft on the motor. Cut an X in the other end to fit the fins on the bomb/missile. Put the motor in a vise, stick a bomb/missile in the X and paint the stripe with a fine brush.
You could probably find a way to do the same thing with an electric screwdriver, drill motor, etc.
Of course, if you're talking about painting stripes lenghtwise, that won't work and I now look like a total idiot. Big Smile [:D]
Posted by berny13 on Tuesday, April 22, 2003 9:58 PM
Decals are the way to go. Use black, yellow and brown decals and use a new #11 blade to cut them into strips. It will give a much better looking, sharp lines for the missiles. Check your references on where to place the colored decals, as not all missiles were marked the same.
Berny
 Phormer Phantom Phixer
On the bench
