1:72 F18
    May 2003
1:72 F18
Posted by nsclcctl on Monday, May 5, 2003 11:46 AM
I am currently building an Itelera (spelling?) 1:72nd F18. What is a good color scheme. I was going to prime it flat white and do upper dark gull grey and lower lighter gull grey. Are they usually painted different upper and lower surfaces?
Posted by Anonymous on Monday, May 5, 2003 12:44 PM
From what I have seen the plane is all one color. Usually a dull grey. But then add the weathering, and the plane has a black "tint" to it. If you want, I 'll go take some pics of an F-18 for ya. Perks of being military brat and having a Marine Air Base in you "backyard"
Posted by Butz on Monday, May 5, 2003 2:42 PM
Whaz up nsclcctl,
The F-18 was done in a two tone scheme. The over all color is Lt Ghost(compass)Gray FS#36375 w/ the upper surfaces being Dk Ghost(compass)Gray FS 36320.
If you can get a hold of the "Walk Around" book on the 18 by Squadron Signal No.18, you can see in certain pics the tone differences.
I also have a quite a few F-18 pics that I have taken myself and out of all of them 45%(give or take) you can see a diff in the grays(especially on the Canadian variants CF-188's. Its more of a overall Lt Ghost Gray w/ upper surfaces being a med gray)
As ropie mentioned, at times the two colors seem to blend in and looks as if it was one color. This is more so when the a/c has a used look to it(weathered,dingy)
I am sure you can go either way on this and you would not be wrong especially being in 1/72nd.
Hope this gives ya a lil light on the subject.
Flaps up,Mike
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
