- Member since
January 2003
Posted by therriman
on Monday, October 11, 2004 11:43 AM
This is one of those kits:
I decided not to do the checkertail version though. Yes, most of the seams needed work. Especially around the nose. Put the back half together and let it dry fully. Then put the wings on, let set fully, then put the nose together without the engine or it's cover on. You'll need to cut off the cover braces. Then, put engine in and put cover on. This procedure worked well for me. You'll need some filler shim's infront of the manifold behind the spinner. But with patance you'll get a great looking bird.
P.S. I also drilled out the holes in the nose screen's.
Tim H.
"If your alone and you meet a Zero, run like hell. Your outnumbered" Capt Joe Foss, Guadalcanal 1942
Real Trucks have 18 wheels. Anything less is just a Toy!
I am in shape. Hey, Round is a shape!
Reality is a concept not yet proven.
