How to weather decals?
    January 2003
Posted by emo07 on Tuesday, October 12, 2004 11:37 AM
Hi,
I am completing a Tamiya 1/32 Zero with significant weathering to paint. My question is how do I show sun fading to the decals, especially to the bright red national insignia's on wings and fuselage. I have an HP printer and scanner, or do you guys mask and paint these.
thanks
emo07
" When I saw fighters escorting the bombers over Berlin, I knew the jig was up." - Herman Goering
    June 2003
Posted by Lucien Harpress on Tuesday, October 12, 2004 1:13 PM
I for one have never built a Japanese aircraft model. My recomendation, though, would be to cut a circular mask and spray a slightly lighter color. I don't know any way to lighten decals. (You could always just set the decals in the sun for a few weeks.... Big Smile [:D])
My My 2 cents [2c]...
That which does not kill you makes you stranger...
-The Joker
Posted by rjkplasticmod on Tuesday, October 12, 2004 6:24 PM
Just to confuse the issue, many references indicate that the bright red in the hinomura's actually oxidized into a darker, almost maroon red color rather than fading into a lighter red. There have been Aftermarket decal sheets available in the darker color for simulating weathered insignia.
Regards, Rick
Posted by pingtang on Tuesday, October 12, 2004 6:50 PM
I'd mask and paint them. You might find some info on the weathering here:
www.j-aircraft.com.
hope it helps
-Daniel
    January 2003
Posted by emo07 on Wednesday, October 13, 2004 11:45 AM
Thanks guys for the info. I will try to locate aftermarket decals first before attempting to mask.
emo07
Posted by Anonymous on Wednesday, October 13, 2004 10:40 PM
Don't forget that if the camo paint is peeling off then so would the markings. Once your decals are dry & well bedded down, try a light rubbing with micromesh (a very fine wetndry in various grades). If you're lucky, and they don't peel off or shatter, then you'll end up with feathered edges and a faded look to your 'meatballs'.
All the bestBig Smile [:D]
Pete
Posted by wibhi2 on Thursday, October 14, 2004 12:51 PM
You could also use pastels to either darken or lighten decals.
After the deacal is applied and sealed (use a flat since pastels don't really like gloss) then "paint " on a complementry pastel color and build up in layers to get your desired effect.
3d modelling is an option a true mental excercise in frusrtation
Posted by Anonymous on Thursday, October 14, 2004 9:20 PM
Don't forget that on the real thing the meatballs were painted on and as paint wears the color under bleeds through. I always like to spray a light coat of the bottom color over all my decals for a look that can't be beat. Good Luck!
    July 2003
Posted by saltydog on Thursday, October 14, 2004 10:51 PM
my favorite way to age decals is by using an airbrush and painting on the worn look. if you don't own an airbrush then drybrushing works ok to to fade out colors and such. i apply the specified paint job, then i apply a couple of coats of future, then apply the decals. next, i do the wash thing, then commence the airbrushing/drybrushing to dirty up or fade out the decals. if you thin colors down really thin, it will make subtle changes in the color of the decals and surrounding areas that you can build to the desired effect. below are some attempts of said discription. hope this helps and everything turns out like you intend it too. if so, then load up some pics so we can drool take a peek. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by wibhi2 on Friday, October 15, 2004 10:32 AM
Jaysus, Chris. What a series of wonderfully weathered AC.
Gonna have to pick your brain with one of my dental tools so I learn how to do dat.
