I have to say that when I use washes, things can get messy too, you know...
I usually make my wash with acrylic or water-based artist colours (you know those that comes in a tube). The paint on my model is on the other hand often enamel. This is quite important as there's no reaction between different layers of paint.
My waterbased wash is therefore paint and water (or alcohol for acrylics), to which I add a drop of washing up liquid and some white vinegar. The washing up liquid will break the water' surface tension and therefore ensure that the mix goes - and stays - everywhere. The vinegar will help reducing those blotches that you find on your model once your wash has dried off. Using watercolour based washes (not the acrylics though)also has another advantadge: if you are unhappy with it, just remove it by placing your model under running water!
Hope this helps.
