Bf 109 Props
    January 2003
Bf 109 Props
Posted by ADleitch on Sunday, May 11, 2003 6:52 PM
Can anyone tell me if the Bf 109 G4/trop had metal or wooden props?
Thanks
Its Better to Burn out than to Fade Away!!!
Posted by Anonymous on Monday, May 12, 2003 8:48 AM
As far as I know, they were metal from at least the 'E' model onwards, the desert would play havoc with wooden props. Also, unless someone knows different, They would be dark green, quite which shade/RLM number, I'm not sure. All of which doesn't tell you a lot, but it's a start!
    January 2003
Posted by ADleitch on Monday, May 12, 2003 10:06 AM
Thanks for the help, I am lead to believe they were painted RLM 70 Black Green.
    May 2003
Posted by qmiester on Friday, September 5, 2003 9:05 PM
I have seen several pictures of wrecked and scrapped 109's which had what were very clearly wooden props. As far as I can remember they were F's, G's and K,s. Makes sense as they were substituting wood for aluminum in the tails during the last two years of the war.
Quincy
Posted by Anonymous on Friday, September 5, 2003 11:41 PM
I think you are both right; what went on each aircraft depended on the exigiencies of the war and what was available at the time. The Me109 I have personally seen has a metal prop, mind you that is a Spanish build. Hope I didn't add to the confusion!
