1/24 Scale Harrier-advice please.
Posted by TANGO 1 on Monday, May 19, 2003 5:14 AM
Smile [:)]Hi everyone.
A friend has asked me to build him a 1/24 scale RAF GR7 Harrier. The problem is that he wants me to build it from an Airfix GR3 kit.
Does anyone know if there is a conversion kit out there? I have seen GR7's in 1/24 scale at some shows in the UK so I'm hoping that someone will know what is availiable.
I checked the Airfix site and the only harriers they had in this scale were GR3 and FRS1 versions, so I'm assuming that a GR7 kit is not availiable.
If anyone has built one of these kits-please give advice as I have never built anything this big beforeBlush [:I]
Thanks,
DarrenWink [;)]
Regards, Darren. C.A.G. FAA/USNFAW GB
    January 2003
Posted by ADleitch on Monday, May 19, 2003 7:25 AM
Hi Tango1,
to may knowledge the Airfix kits are the only ones out there, I don't believe there are any conversions out there to build a GR7. The project will be extremely hard, especialy with the nose being a completly different profile.
One person you may want to E-Mail is David Parkins of Flightpath. He does an excellent detail set for the Airfix kits. He would be the best person to answer your questions.
djparkins@aol.com
He is one of the most helpful guys I know, and prduces some of the best work in white metal and brass I have ever seen.
Its Better to Burn out than to Fade Away!!!
Posted by naplak on Monday, May 19, 2003 12:20 PM
If you get the GR7 kit, it HAS a conversion right in it. The fuselage that comes in it is the GR3, then you have to cut off the cockpit and noce and attach the new GR7 front.
So the GR7 parts are on a seperate sprue... you might try contacking AirFix to see if you can get just the parts without buying th ewhole kit.
http://www.airfix.com/frame_set.htm
www.naplak.com/modeling ... a free site for modelers www.scalehobby.com/forum/index.php ... a nice Modeling Forum
Posted by naplak on Monday, May 19, 2003 12:23 PM
At least I think that's how it all goes together!
Posted by cmtaylor on Monday, May 19, 2003 4:13 PM
If only it were that simple. There IS NO GR7 kit in 1/24. The Airfix GR7 is 1/72.
The GR3 was a modified GR1
The GR7 is an almost completely new airframe, with new nose, new bulging canopy, new instruments, larger intakes with double auxilliary doors, longer front nozzles, bigger wings...
To see the work involved, get hold of the 1/72 GR3 and GR7 kits and compare the airframes. THEN work out how to build everything 300% larger.
Gentlemen! You can't fight in here; this is the WAR ROOM!
Posted by naplak on Monday, May 19, 2003 4:27 PM
I knew it was something like that... in digging our my 1/24 kit, I see clearly that you are correct!!
Posted by nzgunnie on Monday, May 19, 2003 4:57 PM
It would be a pretty huge job, as listed above, most of the airframe is completely different. I have the 1/24 Sea harrier FRS1, which is basically the old GR1 kit with the new nose section and cockpit/canopy etc. But to make the GR1/3 into a GR7 would be a pretty steep order. For plenty of reference on Harriers try this site:
http://harrier.hyperlinx.cz/
This is the IPMS UK Harrier SIG (Special Interest Group) These guys know just about everything there is to know about Harriers. Try posting a question on their forum and see what kind of response you get.
Posted by TANGO 1 on Monday, May 19, 2003 7:33 PM
Thanks for the intell. guys. You are all right about this one-it's a very tall order! I recon I should talk my friend into the idea of a smaller scale.............
Once again, thanks for your help.
Darren,
Posted by Anonymous on Tuesday, May 20, 2003 6:36 AM
Trumpeter have a 1/32 scale AV8B listed on the Hannants.co.uk website in their Future Releases section.
I think that this will be your only choice as the differences between the 'leaping heap' - the GR3 and the 'plastic pig ' -the GR5/7 would be too much and would
practically require a scratchbuild.
The kit number is Trumpeter TP32229
Posted by TANGO 1 on Tuesday, May 20, 2003 5:41 PM
Oggy4624! You've made my friends day!Big Smile [:D]
Thanks for the info about the Trumpeter kit-very much appreciated.
Regards,
Darren.
