No matter the scale, I always use stretched sprue.
To attach it, I use miniscule amounts of CA (superglue). The technique depends upon how the antenna is to be mounted.
If it goes from a fin attachment point to a mast, I drill a hole in the fin and insert one end with a small bead of CA. I then gently stretch it over to the mast, put a tiny bit of CA on the tip of the mast (or wherever it's to be attached) and simply hold it for a second. Then I trim it with a sharp blade. Using this technique you can either draw it taut, or let it sag as appropriate.
If the antenna is attached to the fin and the fuselage or wing with no mast, I drill two holes, insert each end into these and wait a minute or so. I then light a match, blow it out and pass it under the antenna. The residual heat from the match is enough to draw the sprue taut, if so desired. If you're a smoker, you can do this with one of your death-sticks (
![Wink [;)]](/FSM/CS/emoticons/icon_smile_wink.gif)
![Tongue [:P]](/FSM/CS/emoticons/icon_smile_tongue.gif)
), only be careful because the heat isn't residual, it's constant.
I then dress and paint the antenna as appropriate.
Fade to Black...
