General Suggestions for working with resin parts
Posted by Anonymous on Tuesday, June 3, 2003 8:03 AM
Having taken a 15 year break from the world of plastic modeling, I returned to the fold about 10 months ago. Have worked on and completed a number of plastic model kits. Now, I am getting ready to start a kit (T-34C) containing resin parts. Specifically, the kit has a resin cockpit, seats, and wheels.
Would like your general suggestions for working with resin parts. I usually wash parts using dish soap. Ok on resin as well? How do I detach parts from the molds? Anything else I should think of?
Thanks,
Atomr
    January 2003
Posted by markuz226 on Tuesday, June 3, 2003 9:22 AM
I myself have not built one yet but I suggest that you check out this webpage I found:
http://www.kithobbyist.com/largescaleplanes/tips/Scratchbuilders/resin/resin.htm
Also, try searching "resin kits" in this forum. I have seen alot already and I'm pretty sure they can help.
Posted by Anonymous on Tuesday, June 3, 2003 10:27 AM
I often use resin parts and also build 1/43 racing cars that are all resin. This is how I handle resin parts:
1. Detach the parts with a micro-saw: X-Acto, Verlinden, etc. For very small parts, I use a Xuron shear to nip them off of the resin base.
2. Clean up the part with a micro-file and sand.
3. Wash the parts with any good dish washing detergent. I use a solution of warm water and Simple Green. You might want to use an old tooth brush here, but go gently on small parts.
4. Prime parts with any good primer. I use petroleum based Floquil primer. This will allow you to see any pin holes in the resin. Just dab a little primer on any imperfections with a fine brush and sand when dry. This is also good to use to prime any metal parts.
5. Normal plastic cement will not work with resin. Use any brand of CA super glue. I also use G-S Hypo Cement on parts that need perfect alignment. It allows plenty of time to position the part properly before setting. (See the March 2003 issue of FSM, page 14, under News&Products).
I'm sure there are many successful variations on the above. This just happens to be the proceedure that I use. Haven't had a disaster yet! Approve [^]
Pete
Posted by BlackWolf3945 on Tuesday, June 3, 2003 10:49 AM
The only thing I could add to schmeter pit's excellent advice is this:
Not all resin is created equal, and some resin is rather brittle. Most of the recent stuff is okay, but be careful when cutting resin with nippers, especially small parts. I do this myself, but have been bitten on rare occasion.
Other than that, not much to add!
Fade to Black...
Posted by Anonymous on Friday, June 6, 2003 10:01 AM
markuz226/schmeter pit/blackwolfscd:
Thanks again for the input and suggestions! Really appreciate the assistance.
