panel technique
panel technique
Posted by renarts on Thursday, June 5, 2003 5:53 PM
I have seen a few articles that have shown airbrushing around the edge of panels with a dark coat. As this is painted over with the finsh coat and any camo, as well as the panel lines being enhanced with washes I question the practice.
Is it to create a darker underbase in this area (the outer area of the panel) to accentuate the variation of panel colors, through the covering coat of paint?
i.e. if the aircraft color is white and I use a darker undercoat, the white paint sprayed over this darker coat will have a darker shade than if painted over a light under coat.
    January 2003
Posted by leemitcheltree on Thursday, June 5, 2003 7:38 PM
Mike,
"Pre-shading" the panel lines before the topcoat is applied is very effective way of diving depth for the start of the weathering process, but I find that on camo paint schemes, the second color coat can make the pre-shading disappear a little. The darker coat around the panels can be a very subtle weathering technique if used sparingly. Both techniques work very well.
Cheers,
LeeTree
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by Butz on Thursday, June 5, 2003 8:02 PM
Whaz up renarts,
Here is another way that you can start your pre shading. For me I like to use "scale black" as a primer.
Not only will this aide me in finding flaws,seams and the like but also helps me start the "natural shadowing" effect as well as shading which is what your looking for.
I also tend to do the opposite, instead of going light color(s) to dark I go dark color(s) to light. This process also helps w/ shading and shadowing.
Yes I know this may seem odd but for me I like the method. I guess you could say its more of an artistic side of me as a modeler(thanks Steve, you da manTongue [:P])
Another way to get good effects is how you ratio paint to thinner. The lighter the coats(thinned out) more you have to build on. This also creates "natural shading" and "shadowing".
Hopefully this makes sense in some way or other. If this does not, you can blame Custom's for having me on a 10hr shift(more $$$ to by models though rightTongue [:P]Tongue [:P]).
If you have any questions please feel free to e-mail me at Falcon42177@yahoo.com
Basically in other words EXPERIMENT...!!!!!!!. Try things out for yourself cause you'd be surprised on what you can do....Big Smile [:D]
Flaps up,Mike
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
Posted by Kolja94 on Thursday, June 5, 2003 8:38 PM
this might be complete bunk, but it's what my limited experience with it so far makes me think... i SUSPECT that when I preshade, the black actually gets INTO the panel lines and then since I don't lay the color coats on as thick, I suspect the depth of the panel line remains un-colored, and therefore black (for the record, it's actually "Aircraft Interior Black" which isn't entirely black).
But hey, I may be crazy...
Karl
