hypodermic needles/tubing for guns
Posted by Anonymous on Monday, June 9, 2003 4:56 PM
Okay, so i've see a lot of postings where people are using needles, tubing, or syringes for aircraft guns. One thing i havent found is how you go about applying them to your plane. Do you jam them into the guns that are already there? Or cut off the existing guns and replace them?
I'm fascinated by the possibilities. As always, grateful for your help and advice!Kisses [:X]
merideth
Posted by Anonymous on Monday, June 9, 2003 5:04 PM
I would cut them off and replace them. I did a P-51 Mustang once and in the wing had 3 plastic guns I cut them off and put brass tubing insted.
Posted by Anonymous on Monday, June 9, 2003 6:30 PM
thunderbolt do you have any photos of that? sorry, i'm a total visual learner!
merideth
Posted by renarts on Monday, June 9, 2003 6:49 PM
I think Meredith needs to start watching Discovery Wings and the History Channel...Wink [;)]
If you have an ACE Hardware store near you, look for the k&E display. (thats the rack with the brass, aluminum and steel) it will have a variety of stock that you can get that will make perfect barrells. Brass tubing from the size of mechanical pencil lead all the way up to 1" in dia. Square stock, channel, flat stock, I beam, etc. Really comes in handy. Also see about investing in a pinvice and some wire guage drill bits. This way in a pinch, you can stretch out some sprue and drill out your own barrells. (Besides you'll want to do that for some of the kit barrells too,)
Its alot safer than shaking down junkies....Evil [}:)]
Posted by Anonymous on Monday, June 9, 2003 8:32 PM
I haven't worked with syringe needles yet, but I would try to drill out the end of the barrel and insert the needle there. I think that 50 and 30 cal machine guns look a lot better when you can see the cooling holes in the barrel shroud. If there are no holes in the particular application or they are covered by the wing(i.e. P-51) then replace the whole deal. I'm not sure how hard this would be, since I haven't done it yet, but I will be trying it. Anyway, there it my two bits...
Posted by Anonymous on Monday, June 9, 2003 10:33 PM
mike, dude, i'm ADDICTED to the History Channel...i get mocked for it on a regular basis...i'm a lifelong history junkie, which means my habit doesnt come with the aforementioned needles ;-)
was thinking of heating up the end of some of that tubing and and using it to melt it's way into the pre-exisitng gun barells...whatta you think? would that work?
Posted by Anonymous on Monday, June 9, 2003 11:18 PM
I know I would screw it up if I used heat, especially on such a small piece o' plastic. I would try starting out with an undersized drill bit in a pin vice and drill a pilot hole, then work up to a size the needle or tubing would fit into snuggly. Give it a try on some scrap, but my guess is that the heat and pressure would bulge the plastic.
Posted by wayne baker on Tuesday, June 10, 2003 7:46 AM
I have only replaced guns on P-47's. I cut them even with the wings and then drill new holes for the tubing. I cut it longer so I can adjust for the proper length. Every time I turn on History Channel, my wife reminds me that the Germans still lost the war.
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
Posted by jridge on Tuesday, June 10, 2003 8:15 AM
Take a look at the following websites for .50 cal. barrels. They have the cooling jackets and stainless barrels. Don't bother with the resin guns. They aren;t worth it. The barrels are actually made by Eduard. But, they don't seel them separately. Cut the barrels off the kit guns, use wire drills and superglue to attach the new berrels.
Here's a review: http://www.kitreview.com/reviews/karayabarrelsreviewbg_1.htm
Kayra is a Polish company. AirConniectoin is their North American reseller. Karaya was substantially less expensive than AirConnection.
http://www.karaya.ceti.pl/ or http://www.airconnection.on.ca/
They are pretty cool!
Jim
Jim The fate of the Chambermaid http://30thbg.1hwy.com/38thBS.html
Posted by Anonymous on Tuesday, June 10, 2003 11:15 AM
wow jim...those are unbelievably cool!
Posted by Anonymous on Tuesday, June 10, 2003 12:18 PM
Ok, forget everything i said, just use the karaya stuff!!!! It will take a lot to do my
B-17, though!
Jim, thanks.
Posted by Anonymous on Tuesday, June 10, 2003 1:40 PM
That is hot! Wonder if they have ammo, too.....
Thanks.
Posted by renarts on Tuesday, June 10, 2003 1:54 PM
not enough control with heat and plastic. The tolerance for melting and softening is too narrow. You may chance melting the gun and causing it to become mishapen or "bead up" as the metal touches the plastic.
If you're really jonesing to make some guns, use the tube for the barrel and or the shroud, drill holes through it for cooling vents. The tubing wall is thin enough you could use a pinvice and some wire guage bits. Once painted up it will look slick. Or you could use some plastic rod and do the same. If you wanted to slide the tubing over the existing barrell, just shave the plastic down a bit and sleeve the existing guns.
Posted by jridge on Tuesday, June 10, 2003 2:58 PM
I don't know if you could tell from the pictures, but the barrel sleeves are already "blued" by the heating process used to roll them = no painting.
I have not found any good, affordable ammo chutes. Karaya doesn't makes them. I got some brass ones in a Pro Modeler B-24D kit that are really nice. But, I don't know who made them?
Posted by Anonymous on Tuesday, June 10, 2003 3:21 PM
no sorry i dont have a pic and man the 50 Cal at that web is really cool way to go.
Posted by Anonymous on Tuesday, June 10, 2003 4:45 PM
It sounds incredibly hard to drill holes in a straight line in that fine a tubing - using only a pin vice. I would think you would have to have a drill press or mill to do a good job, and even that sounds like a real pain.
Posted by renarts on Tuesday, June 10, 2003 6:12 PM
I have a jig I made up specificaly for drilling dowels and tubing. It is simply a block of wood with a v groove routed down the center. The v groove cradles the tube or dowel so it doesn't move. There is a line scored lengthwise, about 1/2" from the v groove running parallel to the groove. You take a set of dividers or a compass and put one end in the groove, the other centered on the dowel or tube. Use the scored line as a guide and just lightly mark the tube down the center lengthwise. The rest is easy. Just drill along the scored line.
This also works well for woodworking or plumbing projects.
Posted by mandrake on Thursday, June 12, 2003 7:18 PM
I´ll try to do something easy and simple and cheap je je let´s see how it works.... is gonna be hard but i will let you know, so if some one out there has more ideas please bring them on!! jeje :-)
My Best Regards
Hector Reymundo
Thanks! My Best Regards Hector Reymundo
Posted by Anonymous on Thursday, June 12, 2003 7:40 PM
okay...i think if i try to drill out my guns, i'll wreck the whole kit...one more thing to wait on until i'm a little surer of my skills...it's so hard not to get ahead of myself...there are just so many cool things you can do!
Posted by Anonymous on Friday, October 10, 2003 2:23 PM
Meredith, I have been doing my aircraft guns with hypo needles for a long time, luckly were I live (Caracas) you don't need a prescription to buy them. What I do is to select the gauge of needle according to the acft. scale, cut the plastic one off and redrill the hole with a pinvise drill, then cut the needle to proper size with a dremel cutting wheel, don't forget to deburr it, after that heat the needle in order to get a bluish tint and proceed to glue it in position. Keep up the good work.
Delfin
Posted by Anonymous on Friday, October 10, 2003 2:30 PM
Meredith, I forgot to tell you, this also works for pitot tubes as they are heated items and after a while they also get a bluish-burned color.
Posted by Anonymous on Sunday, October 12, 2003 9:21 AM
Has anyone else noticed that the metal application tube from Revell Contacta adhesive is about the right size for a 1/48th cannon? Insert a needle & roll under a sharp knife to cut it to length. Then watch it go ping! across the room, oh dear!
Ahem, hold onto the end you're cutting off!
Pete
    May 2003
Posted by qmiester on Sunday, October 12, 2003 7:50 PM
I've been using hypodermic needles for several years - I use a micrometer to determine the od of the needle and then use the nearest size drill in a pin drill - have used some of the larger sizes to make pitot tubes
Quincy
Posted by Anonymous on Monday, October 13, 2003 11:17 AM
it is easier to drill first the sprue and stretch afterwards,if correctly pulled the hollow barrels will look good. syringe can be expensive in the long run, tubing is more economical.
Posted by jridge on Monday, October 13, 2003 3:52 PM
What gauge needles do you use for 1/48 scale .50 & .30 cal.?
How/where can you get hypodermic needles in the USA wihttout a perscription?
Posted by Butz on Tuesday, October 14, 2003 12:18 AM
Hey Mer,
Long time no chat my friend..!! If you ever decide to use any of the choices here, rather than the molded in gun barrels, try this.
Use a fine round file and lightly sand(file) the gun barrels down so that you will have a hallowed out half circle. Repeat this for the other wing half as well.
As you are doing this, dry fit the needle,syringe,hypodermic needles or what you see that works for ya.
So when you go to put the wing halfs together and when it it is time to insert and glue the needle, it will have a nice fit(some minor sanding/filling may be required).
You will come across a few models that you have to put the barrels in as a seperate piece and if thats the case, just dry fit your alternate barrels in the hole and see what needs to be done.
If you think about it, it is not really that hard. Remember its mind over matter. If you dont mind it, it wont matter. Sound familiar?? Ya just gotta have faith in yourself thats all.Tongue [:P]Wink [;)]
Flaps up, Mike
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
