B-25 Dio
B-25 Dio
Posted by Anonymous on Friday, June 13, 2003 8:09 PM
Hey all!!!Tongue [:P]
I'm working on a diorama of my B-25J in the pacific, and plan to have it on a grass field.What would be the best material to use? Any other tips for doing such a dioramaQuestion [?]
Lancaster_lover
Cool [8D]Bandit's!!! 12 O'Clock High!!!
Posted by Anonymous on Friday, June 13, 2003 10:07 PM
Check out your local hobby store for "static grass." Looks pretty real for most dioramas as long grass, depending on scale. For the actual field, you could use coarse green felt, as long as it's tightly woven.
Posted by Melgyver on Saturday, June 14, 2003 1:00 PM
I would think "packed coral" would be better suited for the Pacific Theater. Never saw any grass in my Dad's photos. He was 5th AAF worked on A-20's and B-25's and a lot of other stuff.
Clear Left!
Mel
Posted by BlackWolf3945 on Sunday, June 15, 2003 9:28 PM
I'd go with Melgyver on this. Most of the airstrips seem to have been almost totally devoid of vegetation except on the outer fringes.
The type of "soil" really depends upon what island the airstrip is on and where on that island the airstrip is.
If you don't care about any of this, just do what you want and don't worry about what "should and shouldn't be".
As far as the grass, static grass is my fave. For dirt, I use dirt. Real dirt, sifted, is really good stuff. I usually brush some thinned white glue onto the base and cover it with dirt. Let it dry and then shake, tap and blow off the excess. Touch up wherever necessary. If you want to change the color, either mix in some powdered pastels, or mix some flat water-based paint in with the glue. The dirt dissolves into the glue some, and will mix with the pigment.
As for the grass I, again, brush on some thinned glue and then sprinkle a ton of static grass onto the appropriate areas. You can blow horizontally across the top of the base to make the stuff stand up. Let it dry, then remove the excess as with the dirt. Make sure to try and save as much of this excess as you can, there will be alot of it and you can re-use it.
I usually paint the grass when it's dry, staring off with a dark green and then working my way up to light greens, yellows, browns... whatever look you're trying to achieve.
This ain't the best photo, and it ain't my best example of grass, but I developed the techniques I described above while doing this base.
Click on the picture for a larger image.
Fade to Black...
Posted by Anonymous on Monday, June 16, 2003 4:39 AM
Black wolf you got right ....I make stuff like for a bord top game call warhammer 40k. Some people do even get what after them you did a really good.... Whew!! sometihng i really know about comes up where I can let some advise or understand!!! lol the plane looks tooooo cool. hope to be that good some day!
Posted by Anonymous on Monday, June 16, 2003 8:15 PM
According to my research, Jaunty Jo served in Biak Island, New Guinea during May 1945. Maybe I'll try a google search on the web to see if I can find some runway pics......
Lancaster_lover
