- Member since
Posted by berny13
on Tuesday, June 17, 2003 9:23 PM
I have to add to renarts post. Not all bullet holes are round. If the bullet entered the aircraft at an angle, it will dig a trough in the skin. Where it enters the airframe it will leave an elongated hole. If the area is thin, like a control surface, the exit hole will be just the reverse of the entry hole. Any hard object to deflect the bullet's path would cause it to tumble and leave a bigger hole on exit. I have seen plenty of aircraft with battle damage.
Berny
Phormer Phantom Phixer
On the bench
TF-102A Delta Dagger, 32nd FIS, 54-1370, 1/48 scale. Monogram Pro Modeler with C&H conversion.
Tamiya F-4D Phantom II, 13th TFS, 66-8711, 1/32 scale. F-4 Phantom Group Build.
