To glue or not to glue
Posted by Anonymous on Monday, June 23, 2003 2:51 PM
I have a 1/32 F-15E. I already built it and there will be pictures later on. My question concerns the nose cone. It won't stay on, even though the instctions say it will. Should I glue it, even though I want to show the radar?
Posted by berny13 on Monday, June 23, 2003 3:11 PM
If you want to show the radar, then do not glue it on. Have you tried using shims to make it fit tighter? Sometimes that is all it takes.
Berny
 Phormer Phantom Phixer
On the bench
Posted by Anonymous on Monday, June 23, 2003 3:25 PM
Sean - This happened to me on a number of occasions, not just with nose cones, but with other parts that you want to move and/or remove to show detail. I'm sure there are some pro's that can recommend a "good" fix, but I always rely on some good old clear Scotch tape. attach a sliver of scotch tape put on the underside (inside) of the nose cone with the "sticky" side facing up and a 1/4 inch or so hanging out. Then, tilt the nose cone up and attach to plane, use a toothpick or something to attach the tape to the inside of the plane and drop the cone. You may have to play areound with it a bit, but when you get it just perfect, you will be able to lift the nose conse and expose the radar & you will never see the tape on the underside. Hope this quick and simple trick helps you in the near term. At least you won't glue it and hide all the hard work you put into detailing the radar, etc.
Paul
Posted by BlackWolf3945 on Tuesday, June 24, 2003 9:54 AM
Duct tape, baby!!! Wink [;)]Tongue [:P]
It's just a joke...
Fade to Black...
Posted by berny13 on Tuesday, June 24, 2003 10:37 AM
Only you could come up with an answer like that. The fix all, repair all, sticky wonder duct tape Wink [;)]
Berny
On the bench
Posted by BlackWolf3945 on Tuesday, June 24, 2003 11:44 AM
Gee, thanks Bern. Evil [}:)]Tongue [:P]
To glue, or not to glue... THAT is the question. Whether 'tis nobler to expose the radar...
Fade to Black...
Posted by Anonymous on Tuesday, June 24, 2003 5:21 PM
if it moves...duck tape it.......if it doesnt move...WD40 it
