Testors has a color in the automotive colours range of the Model Master line called "Ivory", I find that if you add just a touch of gloss white to it, paint the inside of of a modern burner can with it and flat coat it, it almost perfectly matches that scorched white colur.
After that, I take a cotton swab dipped in dust from artist's charcoal and make straight lines starting from the final fan stage of the engine to the outer lip of the burner can.
If you dip the swab lightly in the dust, you can control the density of the black streak it leaves quite well.
After that you just flat coat to seal it in and you're done.
