best way to simulate "concrete"
Posted by Anonymous on Thursday, July 3, 2003 8:17 AM
Hi, I'm working on a 1/32 Tomcat now and after it's finished, I want to make an aircraft carrier diorama or display board for it. What's the most realistic way to simulate the runway/roads/concrete in general? I want it to have the right texture as the real thing, yet I can't use the real thing because the grains would look to big. Any ideas?
Posted by Anonymous on Thursday, July 3, 2003 9:07 AM
If you want to simulate a carrier flt deck the easiest way would be to select a sheet of 'wet and dry ' sanding paper suitable for the scale of your kit
ie 400 grit for 32nd scale ,6 or 800 for 48th etc and attatch it to a base with
3M spray glue.
Spray it grey for concrete and weather it .
You can even mix different grit sheets like 400 with 600 to simulate different textures in the concrete and a big plus is your model will never slide off of your diorama.
Posted by Anonymous on Thursday, July 3, 2003 10:03 AM
In addition to the above, before shading and weathering, use the solvent based Floquil concrete as the base color. It is perfect. Don't use the Floquil water based acrylic concrete. It dries too green.
The Floquil primer is also a good shade to use. It is slightly grayer than their concrete.
Pete
    May 2003
Posted by karlwb on Thursday, July 3, 2003 1:32 PM
I'm working on a display base at the moment, depicting some concrete runway and grass on the border.
I've used the thick card from the back of A4 note pads, various shades and slightly different thickness to simulate the concrete settling over many years. I've used pastel colours to shade the edges and I'm going to use railway scenery for bushes and greenery.
    June 2003
Posted by garys on Thursday, October 30, 2003 2:00 PM
Artist matte board, suitably painted, looks good in larger scales, and if you want to get crazy you can cut them into individual panels, join them together to vary the "grain" and run a bead of black acrylic (tube) paint from a syringe in the joints.
Posted by ckfredrickson on Thursday, October 30, 2003 4:25 PM
Why not plaster?
You may also want to check what model railroaders have to say... they frequently incorporate roads into their displays.
