I want to get serious with the hobby...
Posted by Anonymous on Friday, July 4, 2003 9:05 AM
Hi, I'm sort of a rookie with it comes to modeling. I've modeled a few of Tamiya's 1/24 cars and 1/12 motorcycles. For those small projects I only used Tamiya's acrylic paint, which is harmless.
Now I want to delve deeper into the hobby, because I actually like it. But I want to expand beyong acrylics paint, I want to use more durible enamels or lacquers for my future projects. My problem is this:
My house isn't too big so I can't afford to have my own "workshop". Previously when I used the harmless acrylics, I just airbrushed in my room with the windows open, which is OKAY. But enamels and lacquers are a different story. I can surely get one of those chemical gas masks, but they only prevent ME from breathing the vapors, but they don't protect my family or my room. I never really understood how those spray booths work, do you hook them up to a window with a fan to suck the fumes to the outside?
Another option is to work outside, but outside, there are many dusts and particles, they might drop on my finish before the paints even get dry.
I wonder what you guys do to paint. Since I plan to dedicate myself to the hobby, I want to devise a safe, efficient, and clean way to paint, it'll be a long term investment, thanks.
Posted by wibhi2 on Friday, July 4, 2003 11:28 AM
I believe the hood has it's own fan attached and you just hook a flexiable duct to the window opening. You may also want to try a recirculating hood.
Me, I use enamels and oils. My airbrush station is located directly in front of aa window and I always spray towards it (even in winter). Although not recommended - I don't use a mask and my family never complains about the stench (tho they used to before I had the window).
You can work outside and not worry about dust particles (which are inside as well) if you construct a suitable cover ( a garbage bag, preferably white since it reflects all colors within the sun's spectrum- streched over a bass wood frame). Just remember to keep it in the shade while drying
3d modelling is an option a true mental excercise in frusrtation
Posted by gregers on Friday, July 4, 2003 7:20 PM
Hi. I just want to add my two pence worth. I am a spray painter by trade and trust me you realy should wear a spray mask. lungs were not designed to digest, enamels, acrilics, waterbased, epoxy or two pack paints. NONE ARE TOTALY SAFE no matter what the manufacturers would have us belive. spray in your room with the door shut a window open and a fan in the window blowing the fumes out (don't spray too near the fan as paint has a low flash or ignition point when sprayed and fan motors can produce sparks! -low risk i know but worth mentioning-) and WEAR A MASK. I can't stress the last point enough and i don't want to be alarmist but some types of paint have been linked to cancer and most two pack paints (not normaly used in modeling) contain cyanide and you need air fed masks with an external and filterd air suply to use them safely. Sorry for banging on about this but safety is paramount and lastly don't trust a dust mask to protect you, it won't....Greg
Why torture yourself when life will do it for you?
Posted by wibhi2 on Friday, July 4, 2003 10:26 PM
Gregers is right.
I do so out of personal choice. -:0)
I've spent years in the construction industry. Dust masks are really only good for light demolition and wood sanding work, beyond that use a filtered mask.
Posted by Anonymous on Wednesday, July 9, 2003 2:18 PM
What kind of gas mask do you guys use? I brought a $20 one from a hardware store and it doesn't quite fit my face. I can't believe the manufacturer expected a MOLDED, relatively inflexible mask to fit everyone's face airtight!!! :((
