Please help me in this Italeri F/A-18E model
Posted by Anonymous on Thursday, July 10, 2003 9:58 AM
please give me simple building techniques from anyone who is familiar with this type of brand. even if you don't know, still please give hints. thanks
Posted by berny13 on Thursday, July 10, 2003 10:19 AM
That is a tall order. What type of hints do you need? My suggestion is to go over this forum and read posts on filling, sanding, finishing etc. Then if you have a specific question that wasn't mentioned, then post it and I am sure someone will be able to help. Good luck.
Berny
 Phormer Phantom Phixer
On the bench
    June 2003
Posted by allan on Thursday, July 10, 2003 10:26 AM
I havent built any F/A-18Es, but since your question has reference to the brand, well, lets see.
Italeri carries kits originally made by other brands, such as Zvezda, Dragon, and ESCI. Conversely, some Italeri kits are or have been marketed by other manufacturers. The Tamiya 72nd line is an example (although not all are Italeri kits). So its hard to tell you exactly what to expect. I'll proceed with Italeri originals.
The plastic is generally softer than what youd find in a Monogram, Hasegawa or Academy, so take it easy on the sanding. The details are okay, but the engraving on some samples are just a bit on the heavy side. Canopies are usually thin, which is great if you pose them in the open position.
So far I have noticed two decal suppliers for Italeri: Cartograph and Zanchetti. Cartograph decals are a little thick which makes for difficulty in trying to get them to conform to contours, and have adhesion issues. Zanchetti is far better, and usually has little or no silvering.
Hope this helps.
No bucks, no Buck Rogers
