Finally finished--Fw-190D-9 Red 1 of the Galland Circus--April, 1945
    January 2005
Posted by uproar on Wednesday, October 19, 2005 8:48 PM
Well, after months I've finally finished it, first model in 27 years--its the Tamiya kit, 1/48 with EagleCal decals, Aires cockpit, Eagle Editions resin prop, gun cover, cowling, wheels, Eduard PE landing flaps, Cutting Edge control surfaces, Model Design Construction resin wheelbay/engine set (with solder wire for hoses and plumbing), Moskit exhausts, brass tubing for the gun barrels on the wings and fuselage, painted with Color of Eagles RLM acrylic colors, weathered with Tamiya Smoke acrylic, Van Gogh oil paints, and Tamiya weathering powders.....antenna wire is fishing line, threaded through tiny .0078" drilled holes and CA glued. I also used thin brass wire for brake lines, wrapped with strips of thin styrene. The original Red 1 shows some substantial fire damage of the windscreen (essentially blackened), as well as the starboard fuselage, just forward of the cockpit, in all known photographs of this portion of the aircraft--this I have attempted to recreate, as well as the splinter damage to the propeller blade and the overpainted white spiral on black on the propeller hub. Apparently, the fire may have been deliberately set in an attempt to destroy the craft to keep it out of Allied hands. What do you think? Any critique is welcome...
Yes, I know the base isn't painted yet--but it looked cool anyway.
    January 2005
Posted by jinithith2 on Wednesday, October 19, 2005 8:50 PM
great looking build! I like how the engine (am I correct?) shows through the wheel bay things, especially the detail!
someone's gotta clean that bird up...Big Smile [:D]
    January 2005
Posted by uproar on Wednesday, October 19, 2005 8:57 PM
Yes, that is the engine--that was a conversion from the original kit, which had the wheel wells fully enclosed from the engine area....when the Fw 190A was converted to the 190D, the medial walls of the wheel wells had to be eliminated to make room for the large Jumo in-line engine. The Tamiya kit incorrectly has the Fw 190A wheel wells.
Thanks!
Posted by djmodels1999 on Thursday, October 20, 2005 2:09 AM
All I can say is that is was well worth the wait! Thanks for sharing!
    September 2004
Posted by lerxst1031 on Thursday, October 20, 2005 4:37 AM
Looks GREAT! Love all the aftermarket details!
Fred
    June 2005
Posted by Matt90 on Thursday, October 20, 2005 6:12 AM
Who's personal aircraft was this? Amazing build! The only words I have to describe it are Whattheholy!%!
''Do your damndest in an ostentatious manner all the time.'' -General George S. Patton
    January 2005
Posted by uproar on Thursday, October 20, 2005 8:17 AM
The pilot of the Red 1 was Lt. Heinz Sachsenberg. He was one of the best of what was left of the Luftwaffe pilots by the waning years of the war, and he and others were picked by Adolf Galland to protect his JV44 Me262 fighters during take-off and landing, their most vulnerable moments....more on the JV44:
http://home.att.net/~jv44/jv44wurger.htm
And a good photo of the Red 1, showing the charred windscreen:
http://rafiger.de/Homepage/FBMuseum/Info-JV44/Info-JV44.htm
Thanks for all of the kind comments, guys. I know the paint is a bit thick (I've never used a DA airbrush before), and I didn't get the panel lines to stand out well, but I'll be a bit more organized on my next build.
Tomorrow is my birthday--think I'll start on a tank! Smile [:)]
    September 2003
Posted by blkhwkmatt on Thursday, October 20, 2005 9:14 AM
looks like a greta little Dora!! Good job and welcome back to the hobby. I wish that I'd nown that they were based near salzburg seeing as I was there two weekends ago, would have made a great little side trip to find the old airfield!!!
Thumbs Up [tup]Thumbs Up [tup]
Quidquid latine dictum sit, altum videtur!!! - Anything said in Latin sounds profound!
    April 2005
Posted by wing_nut on Thursday, October 20, 2005 10:33 AM
Good job and welcome back.
Marc
    May 2004
Posted by KINGTHAD on Thursday, October 20, 2005 12:32 PM
Nice looking bird
Thad
  • From: Aaaaah.... Alpha Apaches... A beautiful thing!
Posted by Cobrahistorian on Thursday, October 20, 2005 2:09 PM
Uproar,
She's lookin very good! I like the fire damage too! I'm building mine as she would've appeared operationally. Someday I'll get around to finishing her!
"1-6 is in hot"
Posted by waikong on Thursday, October 20, 2005 2:47 PM
Looks great, welcome back to the hobby. As for critique, you mentioned the think paint, I would just add that a nice flat coat would tone everything done a bit. I'll be interested in how you went about painting the bottom (white first, mask, then red? How did you get the spacing even?) Thanks for sharing your work.
Posted by rjkplasticmod on Thursday, October 20, 2005 3:05 PM
Excellent build & a unique presntation. Well done.
Regards, Rick
    January 2005
Posted by uproar on Thursday, October 20, 2005 3:10 PM
I painted the underside white, then masked the stripes with Model Master tape (would have used Tamiya tape, but they don't make it that thin!), and airbrushed red....unfortunately had a lot of bleeding under the tape, so I had to remask off the red and repaint the stripes white--a lot of time and effort. I measured the spacing and width of the stripes (1/32") directly off of the color artist's renditions of the underside of the aircraft from the book "Doras of the Galland Circus" by Jerry Crandall--the definitive source on the subject. The underside drawings are 1/48 scale, which helped. Didn't quite get the spacing perfect--but it wasn't perfect on the original aircraft.
As for the glossy sheen, yup, I know, but I've tried everything...something about Tamiya Smoke just doesn't want to tone down....I've given it several coats of airbrushed Model Master flat lacquer, a few coats of Dullcote, don't know what else to try...okay, so its the "Red 1" in the rain..okay? Big Smile [:D]
Note to self...Tamiya Smoke just does not want to hold onto flat lacquer. Any suggestions?
I plan on replacing the Morane antenna--the one protruding from the underside of the fuselage--with one fashioned out of brass tubing and wire. I'll post photos of how it looks. I think the kit antenna looks, well, like an overscale plastic antenna. Thanks so much for the critique and comments...I certainly appreciate any help I can get...
    May 2005
Posted by Balearic on Thursday, October 20, 2005 4:14 PM
Very nicely done. Galland and his men would be very proud of your efforts.
Posted by Buddho on Thursday, October 20, 2005 8:12 PM
Excellent job on the Dora...like the charred wind screen effect.
Regards, Dan
    January 2005
Posted by uproar on Thursday, October 20, 2005 8:50 PM
Thanks, everyone, for the comments and suggestions......
I thought I'd add a few photos of the brake lines on the landing gear--brass wire and thin styrene strips:
I'm also going to replace the Morane antenna on the fuselage with one made of wire and brass tubing, hammered flat.
    October 2004
Posted by Allen109 on Thursday, October 20, 2005 10:12 PM
There's no way you've been out that long,that bird looks too good.Keep it up.
    January 2005
Posted by uproar on Friday, October 21, 2005 5:49 PM
Here's a few photos of the Morane antenna I just replaced--the kit part looked very cheesy and overscale...I CA cemented thin wire into thin brass tubing, then hammered it flat, and glued it into place--I think it looks so much better:
Posted by waikong on Monday, October 24, 2005 8:41 AM
The new antenna looks great. Thanks for info regarding the paint job, sounds as difficult as I imagined it to be!
As for the flat coat, I've had good success with PollyS Flat coat over smoke, it water soluable so its easy to clean up. Here's a picture of Tamiya smoke exhaust stains with PollyS over it in a recent build...
    September 2003
Posted by dragonfly on Monday, October 24, 2005 10:45 AM
Very nice Dora. Nice job on the camo.
Jerry
    January 2005
Posted by uproar on Monday, October 24, 2005 3:36 PM
Actually, painting the underside shouldn't have been as difficult a task as I turned it into--if you make sure you burnish the tape well to the surface of the model, and spray several light coats of paint carefully, without holding the airbrush too close to the surface, the bleeding problem under the tape should be minimized (I went a bit too heavily with the red paint). I used ModelMaster 1/32" masking tape for the stripes, as Tamiya, I don't believe, makes tape narrower than 6 mm.
If you happen to have the Jerry Crandall book on "Doras of the Galland Circus", it has some great 1/48 scale artwork of the undersides of the Doras; otherwise, the EagleCals decal set has similar illustrations to go by as a reference.
I have some PollyScale flat coat ordered which I am going to try, and I'm also going to do a dilute acrylic wash using artist's acrylics to try to bring out the panel lines a bit better. Apparently, I'm not quite finished with this bird yet! I might post a few more photos when I finally get it where I want it. Thanks for your comments and critique!
    December 2004
Posted by jboutin on Monday, October 24, 2005 3:56 PM
I really like the doras, you did an excellent job on a must have version of the doras. Well done and thanks for sharing.!
JAY - fighting evil since 2:15pm, July 8,1976 -
    March 2004
Posted by Mark Joyce on Thursday, October 27, 2005 11:07 PM
Fantastic build, Rory! Obviously a lot of time, effort, and research went into it. As waikong pointed out, Pollyscale Clear Flat is excellent and should eliminate any sheen.
Mark
Ignorance is bliss
