QUOTE: Originally posted by ezbluesix
Sweet D...whats the base made of? is it a DYI or did you purchase it ?
The base is resin, from www.justplanemodels.com....planning on painting it soon, maybe gluing a little static grass here and there...
QUOTE: Originally posted by ron b
Chipping on the canopy and wing root is very realistic, what technique did you use ? Looks great thanks for sharing. |
I used a Sharpie metallic gray oil paint fine point pen on the canopy (followed the chipping pattern on the photos and drawings), and Tamiya silver enamel marker on the wing root (wish I'd used the finer pen, though).
The kit is the 1/48 scale Tamiya Fw 190D--not the JV44 version, but the "regular" version with tons of aftermarket stuff...
The real plane had some fire damage to the windscreen and the starboard fuselage, forward from the cockpit, from a cockpit fire (possibly deliberate), and splinter damage to a propeller blade.
Here is my original link, with some photos of the underside, wheel, and engine bays...
http://www.finescale.com/FSM/CS/forums/536210/ShowPost.aspx
