Thank you Gumiflex, Jerry, Rick, Bgrigg, and smokinguns !
Gumiflex - I'll add a link here to my article that's posted at ARC. The pics aren't very large, so let me know if you want bigger ones. They're on one of my hard drives, and I could email them. I used Jaguar's resin and PE set on mine. Here's the article: http://s96920072.onlinehome.us/Gal4/3101-3200/Gal3175_Typhoon_Lachance/gal3175.htm
Jerry - I used the out-of-production AeroMaster Warbird acrylics Primer Red-Brown on the prop and antenna. The yellow leading edge ID bands are kit decals, as are the white "bandages" under the Hinomaru (meatballs).
I used MicroSet when I applied them, and MicroSol to help them conform. I also slit them along the panel lines with a sharp #11 blade. It took about four or five applications of MicroSol. I also dip Hasegawa decals in very hot (but not boiling) water, since this seems to help them.
Thanks again !
