SM 79 Sparviero
    January 2003
SM 79 Sparviero
Posted by el_jere on Tuesday, July 22, 2003 10:14 PM
Hi!!!! I would like buid a Sparaviero in 1:48
Any can you tell me somethig obut the Trumpeter kit, or another
tnx
Jeremy
Res non verba
Posted by robvandodewaard on Wednesday, July 23, 2003 1:29 AM
Jeremy,
check this site http://www.internetmodeler.com/
on this site there is a review of this kit.I recently bought here in The Netherlands and I must say that I like it more than the Classic Airframes example mainly due to the fact that all moving control surfaces are seperate included the wing slats. The interior is a little spars and the ribbed effect on the rear fuselage is a little bit heavy but a few strokes with sand paper will remedy this.But the main reason that I picked the trumpeter kit is the price over here in Holland the CA costs nearly $70 while the trumpeters is nearly $31 . and when youre on a tight budget like I do than the choice is made. And since I always scratchbuildt he interiors
I only uses the exterior of the kits I build(call it a habit left over from the time when I used to work at the Fokker Aircraft factory building cocpits for the Fokker 100) so in this case the choice was easy for me. The only kit I build SOB was the p-47 razorback from Tamiya and maybe later the Gekko from the same company.
hope this is some help
rob
Posted by Torio on Wednesday, July 23, 2003 10:58 PM
And try to find the two books from Ali d'Italia as they have a lot of information and plans
Good modelling
Thank you all for coming José
Posted by rjkplasticmod on Thursday, July 24, 2003 9:40 PM
Kind of weird when a long neglected bird like the SM 79 is suddenly kitted in 1/48 scale by two manufacturers. Classic Airframes has two versions available while Trumpeter has only released the SM.79-II torpedo version. Both are excellent kits, although I have only built the Classic kit ( so far ). The Classic kits provide more detail parts and a superior decal sheet which accounts for some of the higher cost. The Classic kit requires care and patience but no major problems. Haven't started Trumpeters kit yet but it looks very good on the sprues.
Rick
Posted by Anonymous on Saturday, August 9, 2003 10:28 PM
dear sm 79 fans out there:
I have built 2 classic airframe versions and the trumpeter version. I have one classic airframes in reserve. Let me say this--The trumpeter kit, I had to scratchbuild the rear aileron with plastic cards cuz it looks 2 small. But over-all the trumpeter kit has more detailed machine guns than the classic airframe versions. The classic airframe versions look like the real thing--but you can make the trumpeter elegant with a little bit of scratchbuilding like I did....
both are Great models!
Great modelling to us all...
thanks to Paolo Sibani of al soldatino
Sylvia Lo of Fat Lee Leong Hong Kong
Lisa of Greatmodels
Felice Rufolo of italiankits
all my mentors in sm 79 sm-seventynine-ology
From,
Benito
Manila Philippine Islands
Posted by Anonymous on Saturday, August 9, 2003 10:33 PM
Dear SM- 79 Fans,
Please help me perfect the painting of my Baby....
i use air brush but I want a realistic camouflage
benito
of Manila
    January 2003
Posted by el_jere on Saturday, August 9, 2003 10:54 PM
(I hope you speak spanish) i´m feel too lazy to traslate
Benito: pintar un camuflage realistico es posible con el aerografo, de hecho es mucho mas realista que pintar a mano con piceles, aunque existe un pequeño problemita el camuflage del savoia es un patron un tanto complicado para principiantes con el aerografo (que tanta practica tienes con el?) aun teniendo practica es complicado, yo la verdad nunca pinte un Sm 79 pero un amigo mio si lo hizo, si quieres le pregunto como lo pinto, ¿ok?
Jeremy
Res non verba
