Aeriel help.
Aeriel help.
Posted by Anonymous on Wednesday, July 23, 2003 9:49 AM
I need some help. I will soon be getting close to putting the finishing touches to my 1:48 Tamiya Corsair. The problem is, i would like to use a length of my wifes hair for the aeriel, as it offers good scale thickness, but how do i attatch it from the tail to the mast without it pulling away under tension. Also there is a short lenght of wire from the aeriel to the fuselage. Any ideas would be greatfully accepted. Is that how you spell aeriel?
Posted by BlackWolf3945 on Wednesday, July 23, 2003 11:00 AM
Aerial, antenna, radio wire, whatever! Tongue [:P]
Anyhoo, use CA (superglue). Drill a small hole in the fin and attach both ends with CA. My personal choice for antennae would be stretched sprue, but to each his own!
And as to the intersecting line, again drill a small hole into the fuselage and use a bit of CA on both ends, then trim the end that intersects with the main wire using a VERY sharp blade or nippers.
Fade to Black...
Posted by John P on Wednesday, July 23, 2003 2:09 PM
Big problem with using hair is that it changes taughtness with the humidity in the air (didn't you do that barometer experiment with your own hair in 2nd grade? :)). On a humid day, your hair-aerial will sag seriously. On a cold day it could conceivably bend the mast.
I use 2# fish line for my aerials. Drill holes, attach with superglue. The trick is you don't HAVE to attach it perfectly tight. After the superglue sets, light a match, blow it out, and pass the hot smoke over the fishline. It shrinks. Pull the match away at the moment it reaches the right taughtness. Paint it. Yer done. :)
