P-51D landing gear bay & doors interior color
Posted by dariencharlie on Wednesday, November 30, 2005 3:33 PM
Hi all,
I am working on Revell's 1/48 P-51D.  The instructions call for the landing gear bay, and interior of doors, to be chromate yellow.
I am thinking that for in the bay that is correct, but for the inner side of the doors, they should be as the exterior, aluminum.
I know this is the right place for the right answer!
Brian
    January 2003
Posted by leemitcheltree on Wednesday, November 30, 2005 4:12 PM
Brian,
I remember a recent, lengthy post on the FSM forum regarding this very issue - posted (I think) by  Blackwolf3945........and I can't find it.......but I DO remember that it stated (and it quoted from official USAAF manuals, I think) that normally, the P-51B and C gear doors and gear bays were painted with green zinc chromate - and then later in the development process of the aircraft (the D models and later) the paint was deleted from these areas - so the doors and bays of the D were natural aluminum - but there was discussion about the main spar (visible from within the gear bays) as normally having been painted green zinc chromate.
I guess the long and short of it said that for the D model, the gear doors were not painted, and the gear bays were sometimes painted - but often left unpainted - but it also said that sometimes everything was painted, and it was best to check your references for that particular airframe (!!) - possibly a fairly difficult job depending on the airframe you want to model.
But I'd leave the doors unpainted, and paint the bays.
Good luck!!
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by dariencharlie on Wednesday, November 30, 2005 5:57 PM
Thanks very much for the help.  That confirms my conclusion, paint the bay interior color but not the doors.
For Christmas I'll be getting the sounds of the P-51 CD from Ghost!
Brian
Posted by Anonymous on Thursday, December 1, 2005 8:41 PM
I have to disagree Brian.  Mustangs left the facrtory with NMF gear bays and inner door surfaces.  The main spar, at the back of the well was painted zinc chromate yellow.  This is evident in color photos.  The color NMF may have been silver, for lack of a better term,  lacquer.  Colors may have been changed when major maintenance or touch up painting was performed in theater.  Joe
    July 2013
Posted by DURR on Friday, December 2, 2005 8:01 AM
i have seen both yellow and green
and i guess if the door was replaced it may have no paint so that would be ok to
the long and short answer is all 3 and as long as it ain't pink with purple dots it's going to be ok
Posted by rossjr on Friday, December 2, 2005 2:09 PM
Not sure if this is important in this conversation or not but, my understanding is that on North American aircraft (the company not the continent) the wheel door covers were closed anyway, so I am not sure you can see them anyway.  I know model photo's I've seen they are open but most of the references I've seen those doors are closed.
    July 2013
Posted by DURR on Friday, December 2, 2005 2:43 PM
this is true many times but not always
after an aircraft has been sitting a while sometimes as the hydro system loses pressure they open up
by the way yes ross it is relevant to this post
Posted by Anonymous on Friday, December 2, 2005 4:40 PM
Visit www.ipmsstockholm.org.  Use the search feature and you will find a ton of information about P-51s including the multiple color possibilites.
Posted by Anonymous on Friday, December 2, 2005 7:28 PM
rossjr has a valid point.  There was a post on one of the forums I visit and this fellow stated his father worked on F51's  in Korea.  He stated that the only time the inner gear doors were lowered was when maintainance was performed.  They did not bleed down as is the common perception and he felt the models with them down were inaccurate.  Since I read that I have paid attention to P51 photos and I would agree, in most cases the flaps are dropped but not the inner gear doors.  Others may have more information though.  Joe
Posted by Anonymous on Friday, December 2, 2005 8:45 PM
A few years ago, I attended an airshow where 3 P-51D's, a B17G and B24J flew in and landed. The Liberator made a solo low level pass over the runway, and man was she fast. I filmed the planes as they landed, showing that the P51 will close the inner doors after the mains are down. I also have footage from the war documentaries showing the same. On takeoff, the Mustang's inner doors open so the mains can retract. The color I'm not certain, but I believe I have seen them both painted and in natural metal. Hope this helps.
