Masking and metalizers
Posted by Anonymous on Saturday, July 26, 2003 4:33 PM
Any tips on masking metalizers? I usually like to use MM metalizers, but I have ruined a few finishes with masking tape when I pulled the tape off and took paint with it! Can you mask over MM, or do I need to use something else?
Posted by Woody on Saturday, July 26, 2003 4:51 PM
Use Post-It note pads. They come in many sizes and have a low tack adhesive on one edge. I've been using these for over a decade. Super great for isolating one panel to spray a different tint.Wink [;)]
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
Posted by Anonymous on Sunday, July 27, 2003 8:44 AM
Hello Duathlete1,
I tried Post-It Note pads as well, but with me they have their own problems: they're just not sticky enough and blow away when I start spraying. It's also not possible to make them follow the shapes/ texture on models.
I use Tamiya Masking tape which I "grease up" a little by fingering the adhesive side of the tape: it gets less sticky and will be easier to remove. For bigger surfaces I use a combination of both: Post-It notes with masking tape just over the edges to get a good fit.
Good luck!
Gertjan
Posted by Holley on Sunday, July 27, 2003 6:12 PM
Wet newspaper works well, it stays put and doesn't remove the finish.
Holley When all else fails, read the instructions!
Posted by Anonymous on Sunday, July 27, 2003 6:41 PM
lately i have used play doh or silly putty to do alot of maskin easy to form and doesnt pull paint off try that it might surprise u
Posted by Anonymous on Sunday, July 27, 2003 7:03 PM
Thanks - I actually used silly putty on a MiG I just finished. It worked great, but getting a good sharp line might not be too easy. I have heard that some metalizers stick better than others - any experience with this?
